thinkgeo.mapsuite.wpfdesktopedition.mousemovedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.MouseMovedTrackInteractiveOverlayEventArgs
Provides data for the MouseMoved. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.MouseMovedTrackInteractiveOverlayEventArgs
MouseMovedTrackInteractiveOverlayEventArgs()
Constructor of MouseMovedTrackInteractiveOverlayEventArgs class.
MouseMovedTrackInteractiveOverlayEventArgs(Vertex,Feature)
  • movedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be moved.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specified the affected feature.
MovedVertex
Gets or sets the vertex to be moved.
AffectedFeature
Gets or sets the Feature to be affected.
thinkgeo.mapsuite.wpfdesktopedition.mousemovedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
