thinkgeo.mapsuite.windowsphonecore.layerdrawneventargs
ThinkGeo.MapSuite.WindowsPhoneCore.LayerDrawnEventArgs
<!– Class –> This is the event arguments class for the LayerDrawn event on the MapEngine class. It is raised after a layer is drawn.
This is the event arguments class for the LayerDrawn event on the MapEngine class. It is raised after the layer is drawn. This event allows you to manipulate the Layer, or draw something with the canvas after the Layer draws.
Public MethodLayerDrawnEventArgs This is a constructor for the class.
Public MethodLayerDrawnEventArgs Layer, RectangleShape, Object This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCurrentLayer Layer This property gets and sets layer that has drawn.
Public PropertyNativeImage Object This property gets and sets the GeoImage or native image that we are drawing on.
Public PropertyWorldExtent RectangleShape This property gets and sets the world extent to draw.
LayerDrawnEventArgs()
Overloads
Name Type Description
Go Back
LayerDrawnEventArgs(Layer, RectangleShape, Object)
Overloads
This constructor allows you to set the Layer to be drawn, the world extent, and the image you are drawing on.
currentLayer Layer<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer –> This parameter is the layer that has drawn.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent that has drawn.
nativeImage Object<!– System.Object –> This parameter is the GeoImage or native map image.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
CurrentLayer
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.LayerDrawnEventArgs –> Go Back
NativeImage
Return Type
WorldExtent
Return Type
thinkgeo.mapsuite.windowsphonecore.layerdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
