<!– Class –> This class is the base class for all types of Layers.
The Layer class is where all other types of layers are inherited from. It provides the base set of functionality. Though all Layers inherit from this class, we strongly suggest if you decide to create your own layer type that you consider inheriting from the higher level RasterLayer for image-based layers and FeatureLayer for feature-based layers. They provide a rich set of default operations for the various types of layers and are simple to inherit from.
As it is abstract, there are a number of methods you need to implement. The first is DrawCore. In this method, you are responsible for drawing the layer's representation. The other two required methods are OpenCore and CloseCore. These open and close the Layer. In the Open, you are responsible for getting the layer ready for drawing. You should open any file references, etc. In the Close, you need to clean up all file handles, close other objects etc. It is important that the Close puts the class in a state where it can be re-opened in the future. It is different than Dispose, as closed Layers will still exist and can be re-opened later in the mapping life cycle. Many methods (in the layer and in higher level objects) will require that the Layer be open before these methods are called, otherwise they will throw an exception.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.Layer *ThinkGeo.MapSuite.WindowsPhoneCore.BackgroundLayer *ThinkGeo.MapSuite.WindowsPhoneCore.FeatureLayer *ThinkGeo.MapSuite.WindowsPhoneCore.GroupLayer *ThinkGeo.MapSuite.WindowsPhoneCore.InMemoryFeatureLayer *ThinkGeo.MapSuite.WindowsPhoneCore.ShapeFileFeatureLayer
Layer | This is the default constructor for the Layer. |
Close | This method closes the Layer and releases any resources it was using. | ||
Draw | GeoCanvas, Collection<SimpleCandidate> | This method draws the Layer. | |
GetBoundingBox | This method returns the bounding box of the Layer. | ||
Open | This method opens the Layer so that it is initialized and ready to use. | ||
CloseCore | This method closes the Layer and releases any resources it was using. | ||
DrawCore | GeoCanvas, Collection<SimpleCandidate> | This method draws the Layer. | |
DrawException | GeoCanvas, Exception | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. | |
DrawExceptionCore | GeoCanvas, Exception | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. | |
GetBoundingBoxCore | This method returns the bounding box of the Layer. | ||
MemberwiseClone | Object | ||
OnDrawingProgressChanged | DrawingProgressChangedEventArgs | ||
OpenCore | This method opens the Layer so that it is initialized and ready to use. |
DrawingExceptionMode | DrawingExceptionMode | Gets or sets the DrawExcpetionMode when exception happens. | |
DrawingTime | TimeSpan | This property gets the last drawing time for the layer. | |
HasBoundingBox | Boolean | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. | |
IsOpen | Boolean | This property returns true if the Layer is open and false if it is not. | |
IsVisible | Boolean | This property gets and set the visible state of the layer. | |
Name | String | This property gets and sets the name for the layer. |
IsOpenCore | Boolean | This property returns true if the Layer is open and false if it is not. |
Name | Type | Description |
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingProgressChangedEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingExceptionMode –> |
Return Type |
TimeSpan<!– System.TimeSpan –> |
The default value is false.
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Event Arguments |
NOTOC WindowsPhoneMapSuiteCore ThinkGeo.MapSuite.WindowsPhoneCore UpdateDocumentation
