map_suite_web_for_mvc
Map Suite Web For MVC
Note: The page is for Map Suite 10. If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to MapSuite 9.0 Wiki. We highly recommended you to upgrade to ThinkGeo 12.0 if possible which supports both .NET Framework and .NET Core, which is easier to use and get more features over the previous version. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code, please check out ThinkGeo 12 Upgrade Guide.
Map Suite Web For Mvc is a class library that allows software developers to easily add interactive maps and professional GIS features to their MVC applications. Packed with the speed and flexibility of MVC, the simple API that makes coding easy, and royalty-free distribution, Map Suite Web For Mvc enables you to bring your Internet GIS application to market in record time.
Getting Started
Map Suite Web for MVC Quickstart On Windows
Map Suite Web for MVC Hello World
Hello World on Windows (3'09”)
Helps get you up to speed with integrating the Map Suite Web For Mvc map control into your GIS software.
Product Guides
Helps get you up to speed with integrating the Map Suite Web For Mvc map control with mobile UI into your GIS software.
Introduces the dependencies Map Suite Web For Mvc needs as well as their features, versions and source websites.
Walks you through deploying your project using the map control into a windows azure cloud service and register the map control.
Show Map Suite features coverage of different product and different platfoms
Code Samples
In addition to the samples below, we have dozens of interactive Map Suite Web For Mvc sample applications available here and Map Suite Web For Mvc mobile sample applications here.
All Samples
All samples about Map Suite Map Suite Web for Mvc.
Project Templates
These projects show various study cases based on Map Suite Web for Mvc.
Background Maps
InteractiveOverlays
Labeling
Layers & FeatureSources
Miscellaneous
Printing
Projection
Spatial Functions
Styles
Vehicle Tracking
Zooming Panning Moving
Package
Standard
Compare with Barebone
Barebone
Compare with Standard
API Documentation
  • ThinkGeo.MapSuite.Mvc
    The Map Suite Web For Mvc API documentation covers the ThinkGeo.MapSuite.Mvc namespace which resides in the ThinkGeo.MapSuite.Mvc.dll assembly. It contains all of the Map Suite Web For Mvc specific classes such as the map control itself, Overlays, and supported map classes.
  • Client JavaScript API Documentation
    This document defines the client JavaScript functions that are applied to the Map's name. In other words, if you add an Map Suite Web For Mvc map control named “Map1” to the view page, then you would call these functions like “Map1.functionName()”.
Change Logs
  • API Change Log
    This changelog details the changes made to the product for each major release cycle.
Videos
Map Suite Web For Mvc Sample App Walkthrough Video Series
Step through the Map Suite Web For Mvc sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screenshot
Introduction to the Map Suite Web For Mvc
Screenshot
Map Suite Web For Mvc Sample Apps Walkthrough
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
The Map Suite Web for MVC screenshots gallery section displays a wide range of screenshots covering various GIS features of the Map Suite Web for MVC map control.
No extra coding necessary
Includes panning, zooming, scale bar, mini map & more
No extra coding necessary Includes panning, zooming, scale bar, mini map & more
Track multiple markers
Load meta data from XML
Show details in a popup
Track multiple markers Load meta data from XML Show details in a popup
Automatically track multiple vehicle locations
Track weather features
Automatically track multiple vehicle locations Track weather features
Uses ZedGraph classes
Draw track shapes
Edit and rotate shapes
Save shapes to the servers
Draw track shapes Edit and rotate shapes Save shapes to the servers
Design your own tooltips with custom HTML
Include images
Design your own tooltips with custom HTML Include images
Draw track shapes
Puts you in control
Useful for points & labels
Project your spatial data
Real-time rotation
Connect points using the Great Circle model
Show accurate distances
Connect points using the Great Circle model Show accurate distances
Use an online mapping service for your background
Google, Yahoo, or WMS (third party licensing may apply)
Use an online mapping service for your background Google, Yahoo, or WMS (third party licensing may apply)
Draw an image at a point
Frequently Asked Questions
  • General Questions
  • License Questions
    All the frequently asked questions about Map Suite Web for License.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_web_for_mvc.txt · Last modified: 2020/05/19 21:25 by benbai
