map_suite_deployment_license_guide_for_web
Map Suite Deployment License Guide for Web
If we want to publish our web application with Map Suite Components to a server, it is required to setup the deployment license, or a map will be rendered with a “Not Licensed For Run Time” watermark. This guide will introduce you how to setup the deployment license with Map Suite Product Center.
Setup Deployment Server
Please follow the below steps to setup the deployment license.
  • Copy ThinkGeo.MapSuite.ProductCenter.exe from the development machine to your deployment server. The Product Center executable can be found in the “bin/debug” folder of the developing project after the project is compiled. Log into the Product Center, if you have purchased the web products, the “Setup Deployment Server” button will be available on the right side panel.
  • Click “Setup Deployment Server” button. The server deployment dialog will pop up as seen in the following snapshot:
  • Click “OK” to get your deployment license ready. It might take a few seconds to complete.
  • Once setup is finished, the “Not Licensed for Run Time” watermark will gone.
Deploying Applications
You can also install the necessary dependencies with one of the following ways:
1. Several Merge Modules are supplied to assist you in deploying all of our required dependencies. You can download them below:
2. "MapSuiteRuntimeDependencies.msi" tool is supplied to assist you in deploying all of our required dependencies. You can download it below:
map_suite_deployment_license_guide_for_web.txt · Last modified: 2021/09/16 14:01 by benbai
