This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
A setting for AdornmentOverlay that contains APIs to set properties of AdornmentOverlaySetting using in MVC view.
Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
A setting for ArcGISServerRestOverlay that contains APIs to set properties of ArcGISServerRestOverlaySetting using in MVC view.
Represents an overlay object that gets images from Microsoft's Virtual Earth server.
A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
Represents a FeatureOverlay whose features can be added or edited at the client side.
A setting for EditFeatureOverlay that contains APIs to set properties of EditFeatureOverlaySetting using in MVC view.
Serves as the base class for the overlays that contain features and paint the features at client side.
A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
This enumeration specifies the picture formats when getting images back to client from Google Maps.
A setting for GoogleOverlay that contains APIs to set properties of GoogleOverlaySetting using in MVC view.
Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
HtmlHelper extension for providing access to the Mvc controls inherited from MvcControlBase
Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
Represents a small image that displays at the center of the map when the map is loading.
A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
Represents a company logo or other logo-type image that displays in the lower right corner of the map.
Contains the different map tools as properties and acts as an entrance for setting these map controls.
A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
A setting for MarkerOverlay that contains APIs to set properties of MarkerOverlaySetting using in MVC view.
This class is the base class for all classes that define the styles applied to the markers.
A setting for MarkerStyle that contains APIs to set properties of MarkerStyleSetting using in MVC view.
Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
A setting for MeasureMapTool that contains APIs to set properties of MeasureMapToolSetting using in MVC view.
The display system units for output measurements. Supported values are �english�, �metric�, and �geographic�. Default is �metric�.
A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
A setting for MouseCoordinateMapTool that contains APIs to set properties of MouseCoordinateMapToolSetting using in MVC view.
This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
A setting for MouseMapTool that contains APIs to set properties of MouseMapToolSetting using in MVC view.
This is an asynchronous HTTP handler which is used to handle web map services.
This Class defines the utility for managing, registering or adding the client script libraries and script files of Mvc application to the page.
This Class defines the utility for managing, registering or adding the Css files to the page which included the specified control.
This class provides a abstract base class to defines the fluent interface for configuring the Mvc control.
This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
A setting for Overlay that contains APIs to set properties of OverlaySetting using in MVC view.
Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
Serves as the base class that defines the methods and properties common to all types of popups.
A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
A setting for SimpleMarkerOverlay that contains APIs to set properties of SimpleMarkerOverlaySetting using in MVC view.
A setting for TouchMapTool that contains APIs to set properties of TouchMapToolSetting using in MVC view.
This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
This class allows you to match a value with data in the feature to determine how to draw the feature.
A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
A setting for WmsOverlay that contains APIs to set properties of WmsOverlaySetting using in MVC view.
A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
Represents an overlay object that gets map images from the WMS servers.
This enumeration represents which projection will use for world map kit.
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
This is the base class for NativeTileCache system which inherits from TileCache class.
This class represents the parameters passed in through the CreatedMemberNode event.
This class represents the parameters passed in through the CreatingMemberObject event.
Indicates how the default value of a member will be dealt with by the modeler.
When applied to a method, specifies that the method is called after serialization of an object graph.
When applied to a method, specifies that the method is called before serialization of an object.
