thinkgeo.mapsuite.webedition
ThinkGeo.MapSuite.WebEdition
WebEdition
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
B
C
  • ClassBreakMarkerStyle
    This class represents a style based on class break values.
  • ClientCache
    This class controls how the map images are cached by the browser.
  • CloudPopup
    Represents the popups that appear in a cloud (a.k.a. balloon) shape.
  • ClusterMarkerStyle
    A kind of MarkerStyle to filter the markers.
  • ContextMenu
    This class represents a right-click shortcut menu used in the map control.
  • ContextMenuItem
    This class represents a menu item of the ContextMenu control.
  • ContextMenuItemClickEventArgs
    This class provides data for the click event of a context menu item.
  • CustomPopup
    Represents a pop up window whose style and background can be customized.
E
F
  • FeatureOverlay
    Serves as the base class for the overlays that contain features and paint the features at client side.
  • FeatureOverlayStyle
    Specifies how the features in a FeatureOverlay are drawn at the client side.
  • FeatureSourceMarkerOverlay
    Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
G
H
I
  • InMemoryMarkerOverlay
    Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
J
  • JsonMemberAttribute
    Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
K
L
  • LayerOverlay
    Represents an Overlay that contains layers.
  • LoadingImageMapTool
    Represents a small image that displays at the center of the map when the map is loading.
  • LogoMapTool
    Represents a company logo or other logo-type image that displays in the lower right corner of the map.
M
  • Map
    This class represents the map control.
  • MapClickedEventArgs
    This class provides the data for the click event of the map control.
  • MapDesigner
    Provides design-time display of web control.
  • MapTool
    Defines the properties and methods that are shared by all controls on the map.
  • MapTools
    Contains the different map tools as properties and acts as an entrance for setting these map controls.
  • Marker
    Represents a small icon on the map that is used for marking a point.
  • MarkerClassBreak
    Represents a break with a value and style defined.
  • MarkerDraggedEventArgs
    Provides data for the MarkerDragged event of the SimpleMarkerOverlay.
  • MarkerOverlay
    Serves as the base class for the overlay that generates and manages markers.
  • MarkerOverlayClickEventArgs
    Provides data for the Click event of the MarkerOverlay.
  • MarkerStyle
    This class is the base class for all classes that define the styles applied to the markers.
  • MarkerValueItem
    This class represents one value in a ValueMarkerStyle.
  • MarkerZoomLevel
    Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
  • MarkerZoomLevelSet
    This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
  • MeasureMapTool
    Represents the measure map tool which allows measurements for features.
  • MiniMapMapTool
    Represents a mini map panel in the lower right corner of the map.
  • MouseCoordinateMapTool
    Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
  • MouseMapTool
    Determines whether the map can be operated by mouse.
  • MultiThreadTileResource
    This is an asynchronous HTTP handler which is used to handle web map services.
O
  • OpenStreetMapOverlay
    This class is used to display data from OpenStreetMap server.
  • Overlay
  • OverlaySwitcherMapTool
    Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
P
  • PanZoomBarMapTool
    Represents the panning and zooming panel in the upper left corner of the map.
  • PanZoomMapTool
    Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
  • PointMarkerStyle
    Represents the ordinary marker style.
  • Popup
    Serves as the base class that defines the methods and properties common to all types of popups.
S
  • ScaleLineMapTool
    Represents a graphic line marked with numbers indicating the map's current scale.
  • ServerCache
    This class controls the cachablity of the map control at the server side.
  • SimpleMarkerOverlay
    Represents a MarkerOverlay object to which you can add markers directly.
  • SingleThreadTileResource
T
V
  • ValueMarkerStyle
    This class allows you to match a value with data in the feature to determine how to draw the feature.
W
Structures
Enums
B
  • BingMapsStyle
    This enumeration specifies the map types available from Bing maps.
C
  • CursorType
    This enumeration determines the cursor that appears when the pointer moves over the map.
G
  • GoogleMapType
    This enumeration specifies the map types available from Google Maps.
M
  • MarkerDragMode
    This enumeration specifies how the map markers can be dragged.
  • MeasureType
    Defines the different types of the MeasureMapTool.
  • MeasureUnitType
    The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
  • MouseCoordinateType
    This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
O
R
  • ResourceDeploymentMode
    This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
T
  • TileType
    This enumeration specifies whether the overlay uses tiling.
  • TrackMode
    Defines the different modes of the EditFeatureOverlay.
  • TrackZoomMaskType
    Defines the different zoom box key code of key for the MouseMapTool.
  • TransitionEffect
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
W
Interfaces
I
  • IJsonSerializable
    Allows an object to control its own serialization and deserialization to/from a JSON string.
  • IRequireId
    This interface defines an Id property that is used by the GeoKeyedCollection.
thinkgeo.mapsuite.webedition.1442997190.txt.gz · Last modified: 2015/09/23 08:33 by admin
