Represents a small icon on the map that is used for marking a point.
Marker(Double,Double,WebImage)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Marker#ContextMenu
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Marker#Popup
Gets or sets a value indicating the interval that should elapse between when the mouse moves over the marker and when its popup window displays.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Marker#PopupDelay
Gets or sets a PointShape object that represents the current location of the marker.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Marker#Position
Gets or sets a GeoIcon object that determines the appearance of the marker.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Marker#Marker.28WebImage.29
Gets or sets a float value between 0 and 1 that indicates the transparency level of the marker.
The <strong>Opacity</strong> property enables you to specify a level of transparency for the marker. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the marker completely invisible.
Gets or sets a string that represents the unique identifier for this marker. When you add marker into markers collection, it's also the key to find it back, Marker is a virtual control, and we don't allowed to add the same marker in this collection for many times like normal controls.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Marker#Id
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Marker#IsVisible
