thinkgeo.mapsuite.webedition.contextmenu
ThinkGeo.MapSuite.WebEdition.ContextMenu
This class represents a right-click shortcut menu used in the map control.
    • ThinkGeo.MapSuite.WebEdition.ContextMenu
ContextMenu()
  • Initializes a new instance of the ContextMenu class with no menu items specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28.29
ContextMenu(String,Int32)
  • Initializes a new instance of the ContextMenu class with the specified identifier and width.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28String.2C_Int32.29
  • id
    • Description:The key of the context menu in string format.
  • width
    • Description:The width of the context menu.
ContextMenu(String,Int32,String)
  • Initializes a new instance of the ContextMenu class with the identifier, width and CSS class string.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28String.2C_Int32.2C_String.29
  • id
  • width
  • cssClass
    • Description:The CSS class for the context menu.
CloneDeep()
  • Creates a deep copy of this ContextMenu object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#CloneDeep.28.29
  • Description:A deep copy of the ContextMenu object.
ToJson()
  • Returns a JSON string that contains information for creating the context menu at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ToJson.28.29
  • Description:A string for creating the context menu at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#GetType.28.29
whQ=()
wxQ=(Object)
  • target
xBQ=(String)
  • fullId
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#MemberwiseClone.28.29
Id
Gets the identifier of the ContextMenu object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Id
Width
Gets or sets the width of the context menu.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Width
CssClass
Gets or sets the CSS class of the context menu.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#CssClass
MenuItems
Gets the menu item collection of the context menu.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#MenuItems
thinkgeo.mapsuite.webedition.contextmenu.txt · Last modified: 2017/03/16 21:59 (external edit)
