thinkgeo.mapsuite.portablecore.layersdrawingeventargs
ThinkGeo.MapSuite.Core.LayersDrawingEventArgs
      • ThinkGeo.MapSuite.Core.LayersDrawingEventArgs
LayersDrawingEventArgs()
LayersDrawingEventArgs(IEnumerable<Layer>,RectangleShape,Object)
  • None
  • layers
    • Type:IEnumerable<Layer>
    • Description:This parameter is the layers that will be drawn.
  • worldExtent
    • Description:This parameter is the world extent you are drawing.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
Cancel
  • This property gets and sets the value that indicates you want to cancel all of the layers from drawing.
  • None
WorldExtent
  • This property gets and sets the world extent that will be drawn.
  • None
NativeImage
  • This property gets and sets the GeoImage or native image that we are drawing on.
  • None
Layers
  • This property gets and sets the layers you will be drawing.
  • None
thinkgeo.mapsuite.portablecore.layersdrawingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
