thinkgeo.mapsuite.webedition.webimage
ThinkGeo.MapSuite.WebEdition.WebImage
Represents a small image that displays on the map.
    • ThinkGeo.MapSuite.WebEdition.WebImage
WebImage()
  • Initialize a new instance of the WebImage class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#WebImage.28.29
WebImage(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#WebImage.28String.29
  • imageVirtualPath
    • Description:The virtual path of the image.
WebImage(Int32,Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#WebImage.28Int32.2C_Int32.29
  • imageWidth
    • Description:The width of the image.
  • imageHeight
    • Description:The height of the image.
WebImage(Int32,Int32,Single,Single)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#WebImage.28Int32.2C_Int32.2C_Single.2C_Single.29
  • imageWidth
  • imageHeight
  • imageOffsetX
    • Type:Single
    • Description:The offset X of the image.
  • imageOffsetY
    • Type:Single
    • Description:The offset Y of the image.
WebImage(String,Int32,Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#WebImage.28String.2C_Int32.2C_Int32.29
  • imageVirtualPath
  • imageWidth
  • imageHeight
WebImage(String,Int32,Int32,Single,Single)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#WebImage.28String.2C_Int32.2C_Int32.2C_Single.2C_Single.29
  • imageVirtualPath
  • imageWidth
  • imageHeight
  • imageOffsetX
    • Type:Single
  • imageOffsetY
    • Type:Single
CloneShallow()
  • Creates a shallow copy of the current WebImage object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#CloneShallow.28.29
ToJson()
  • Returns a JSON string that contains the information for creating a client image object at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#ToJson.28.29
  • Description:A JSON string that contains the information for creating a client image object at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#MemberwiseClone.28.29
ImageVirtualPath
Gets or sets the virtual path of the image file.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#ImageVirtualPath
ImageWidth
Gets or sets the width of the web image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#ImageWidth
ImageHeight
Gets or sets the height of the web image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#ImageHeight
RotationAngle
Gets or sets the rotation angle of the web image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#RotationAngle
  • Type:Single
FontStyle
Gets or sets the style applied to the text on the image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#FontStyle
FontColor
Gets or sets the color of the text on the image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#FontColor
TextBackgroundColor
Gets or sets the background color of the text on the image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#TextBackgroundColor
Text
Gets or sets the text displayed on the image.
TextOffsetX
Gets or sets the X offset of the text on the image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#TextOffsetX
  • Type:Single
TextOffsetY
Gets or sets the Y offset of the text on the image.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#TextOffsetY
  • Type:Single
ImageOffsetX
Gets or sets the image's X offset.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#ImageOffsetX
  • Type:Single
ImageOffsetY
Gets or sets the image's Y offset.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WebImage#ImageOffsetY
  • Type:Single
IconImagePath
thinkgeo.mapsuite.webedition.webimage.txt · Last modified: 2017/03/16 21:59 (external edit)
