thinkgeo.mapsuite.webedition.markerzoomlevelset
ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet
This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
    • ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet
MarkerZoomLevelSet()
  • Initialize a new instance of the MarkerZoomLevelSet class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#MarkerZoomLevelSet.28.29
GetZoomLevelForDrawing(Int32)
  • Returns the MarkerZoomLevel object whose styles will be applied to the markers based on the current zoomlevel that is passed in.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#GetZoomLevelForDrawing.28Int32.29
  • currentZoomLevelId
    • Description:An int value that indicates which zoomlevel is the current zoomlevel. The int value must be a number from 1 - 20.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#GetType.28.29
HRU=(Int32)
  • id
5hM=()
5xM=(Object)
  • target
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#MemberwiseClone.28.29
ZoomLevel01
Gets the MarkerZoomLevel for Level01.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel01
ZoomLevel02
Gets the MarkerZoomLevel for Level02.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel02
ZoomLevel03
Gets the MarkerZoomLevel for Level03.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel03
ZoomLevel04
Gets the MarkerZoomLevel for Level04.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel04
ZoomLevel05
Gets the MarkerZoomLevel for Level05.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel05
ZoomLevel06
Gets the MarkerZoomLevel for Level06.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel06
ZoomLevel07
Gets the MarkerZoomLevel for Level07.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel07
ZoomLevel08
Gets the MarkerZoomLevel for Level08.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel08
ZoomLevel09
Gets the MarkerZoomLevel for Level09.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel09
ZoomLevel10
Gets the MarkerZoomLevel for Level10.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel10
ZoomLevel11
Gets the MarkerZoomLevel for Level11.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel11
ZoomLevel12
Gets the MarkerZoomLevel for Level12.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel12
ZoomLevel13
Gets the MarkerZoomLevel for Level13.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel13
ZoomLevel14
Gets the MarkerZoomLevel for Level14.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel14
ZoomLevel15
Gets the MarkerZoomLevel for Level15.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel15
ZoomLevel16
Gets the MarkerZoomLevel for Level16.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel16
ZoomLevel17
Gets the MarkerZoomLevel for Level17.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel17
ZoomLevel18
Gets the MarkerZoomLevel for Level18.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel18
ZoomLevel19
Gets the MarkerZoomLevel for Level19.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel19
ZoomLevel20
Gets the MarkerZoomLevel for Level20.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevelSet#ZoomLevel20
CustomZoomLevels
Gets a MarkerZoomLevel collection that is used for you to define your own custom zoomlevels.
When you add custom zoomlevels to the CustomZoomLevels collection, the default ZoomLevels 01 through 20 will be disabled. The zoomLevels in the CustomZoomLevels are matched with the scales defined in the Map.ClientZoomLevelScales. For example, CustomZoomLevels[0] has the scale that equals to Map.ClientZoomLevelScales[0].
thinkgeo.mapsuite.webedition.markerzoomlevelset.txt · Last modified: 2017/03/16 21:59 (external edit)
