thinkgeo.mapsuite.webedition.inmemorymarkeroverlay
ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay
Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
    • ThinkGeo.MapSuite.WebEdition.Overlay
      • ThinkGeo.MapSuite.WebEdition.MarkerOverlay
        • ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay
InMemoryMarkerOverlay()
  • Initialize an instance of the InMemoryMarkerOverlay class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#InMemoryMarkerOverlay.28.29
InMemoryMarkerOverlay(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#InMemoryMarkerOverlay.28String.29
  • id
    • Description:The identifier of the overlay, which is used for retrieving the overlay.
InMemoryMarkerOverlay(String,IEnumerable<String>)
  • id
  • featureColumnNames
    • Type:IEnumerable<String>
    • Description:The column names that are associated with the features in the overlay.
InMemoryMarkerOverlay(String,IEnumerable<FeatureSourceColumn>)
  • id
  • featureColumns
    • Type:IEnumerable<FeatureSourceColumn>
GetMarkers(RectangleShape,Int32)
  • Returns a collection of markers based on the extent and zoomlevel that you passed in.
  • The <strong>GetMarkers</strong> method creates the makrers based on the current zoomlevel, the specified extent and the special logic of the MarkerOverlay. The returned markers object will be serialized and sent to the client to create client markers.
  • Type:Collection<Marker>
  • Description:A collection of marker objects that will be serialized to the client.
  • worldExtent
    • Description:The extent that includes all of the markers you want to serialize.
  • currentZoomLevelId
    • Description:An int value that indicates which zoomlevel the map is currently at.
ToJson()
  • Returns a JSON string which contains the information for creating an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#ToJson.28.29
  • Description:A JSON string which is used to create an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#GetType.28.29
GetMarkersCore(RectangleShape,Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#GetMarkersCore.28RectangleShape.2C_Int32.29
  • worldExtent
    • Description:The extent that includes all of the markers that you want to serialize.
5hM=()
5xM=(Object)
  • target
4xM=(String,String)
  • overlayId
  • featureId
OnClick(MarkerOverlayClickEventArgs)
  • Raises the Click event of the MarkerOverlay object.
  • The <strong>OnClick</strong> method also allows derived classes to handle the event without attaching a delegate. This is the preferred technique for handling the event in a derived class. <strong>Notes to Inheritors:</strong> When overriding <strong>OnClick</strong> in a derived class, be sure to call the base class's <strong>OnClick</strong> method so that registered delegates receive the event.
5BM=()
5RM=(Object)
  • target
3xM=(Page)
  • page
    • Type:Page
  • Registers a Javascript library URL string to the client HTML page.
  • The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
  • page
    • Type:Page
    • Description:The page object that is used for registering the javascript library.
RaiseTickEvent(EventArgs)
  • e
    • Type:EventArgs
OnTick(EventArgs)
  • Raises the Tick event of the MarkerOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#OnTick.28EventArgs.29
  • e
    • Type:EventArgs
    • Description:An System.EventArgs object that contains the event data.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#MemberwiseClone.28.29
Columns
Gets the collection of FeatureSourceColumns that is the column definition of the feature data.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#Columns
SuppressingGridSize
Gets or sets the grid size in screen coordinate to suppress markers in current Viewport.
Current ViewPort will be split into several cells by FilterGridSize, one cell will contains only one marker in it, in another word, markers which are near too close will be removed. if the value is greater than 0, this function will be enabled.
FeatureSource
Gets a FeatureSource object by which you can perform queries on the features in the overlay.
ZoomLevelSet
Gets the ZoomLevelSet object that controls the markers' generation.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#ZoomLevelSet
IsBaseOverlay
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#IsBaseOverlay
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#IsVisible
Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#Name
Opacity
Gets or sets the opacity level of the overlay.
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
  • Type:Single
IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Id
Gets the identifier for the overlay to be found.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#Id
AutoRefreshInterval
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
  • Type:TimeSpan
Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#Attribution
OverlayType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#OverlayType
HasClickEvent
IsDefault
HasTickEvent
Indicates whether the overlay supports tick event.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#HasTickEvent
3hM=
Click Occurs when a marker in the overlay is clicked.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#OnClick.28MarkerOverlayClickEventArgs.29
Event Arguments:MarkerOverlayClickEventArgs
Tick Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
thinkgeo.mapsuite.webedition.inmemorymarkeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
