Represents a FeatureOverlay whose features can be added or edited at the client side.
The default mode is TrackMode.None, which means you cannot draw or edit features at the client side. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you can then add points, lines or polygons to the FeatureOverlay. Setting the mode to TrackMode.Edit, you can edit the shapes at the client side.
The <strong>EditSettings</strong> object contains four options: <strong>IsDraggable</strong>, <strong>IsReshapable</strong>, <strong>IsRotatable</strong>, <strong>IsResizable</strong>. By default, all of them are set to true. This means you can drag, reshape, rotate and resize shapes when you are in edit mode. If you set any of these options to false, you prohibit that functionality.
Gets a collection of features that will be serialized to the client for drawing and editing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Features
Gets the FeatureSource of the FeatureOverlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#FeatureSource
Gets a collection of FeatureSourceColumns, which specifies the column names of the feature data.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Columns
Gets or sets a FeatureOverlayStyle object, which determines how the features are drawn at the client side.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Style
Gets the QueryTools that allow you to easily query features from the FeatureOverlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#QueryTools
Gets the EditTools that allow you to easily edit features in the FeatureOverlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#EditTools
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsVisible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Name
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay is a base overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsBaseOverlay
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Id
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#AutoRefreshInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#OverlayType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#HasTickEvent
Tick
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
