thinkgeo.mapsuite.webedition.trackmode
ThinkGeo.MapSuite.WebEdition.TrackMode
Defines the different modes of the EditFeatureOverlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.TrackMode
Items
  • Summary:Specifies that the EditFeatureOverlay can only display shapes. Drawing and editing are not allowed.
Point
  • Summary:Specifies that the EditFeatureOverlay is in point drawing mode.
Line
  • Summary:Specifies that the EditFeatureOverlay is in line drawing mode.
Polygon
  • Summary:Specifies that the EditFeatureOverlay is in polygon drawing mode.
Rectangle
  • Summary:Specifies that the EditFeatureOverlay is in rectangle drawing mode.
Square
  • Summary:Specifies that the EditFeatureOverlay is in square drawing mode.
Circle
  • Summary:Specifies that the EditFeatureOverlay is in circle drawing mode.
Ellipse
  • Summary:Specifies that the EditFeatureOverlay is in ellipse drawing mode.
Edit
  • Summary:Specifies that the EditFeatureOverlay is in editing mode.
FreeHand
  • Summary:N/A
thinkgeo.mapsuite.webedition.trackmode.txt · Last modified: 2017/03/16 21:59 (external edit)
