thinkgeo.mapsuite.webedition.singlethreadtileresource
ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource
This is an asynchronous HTTP handler which is used to handle web map services.
    • ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource
SingleThreadTileResource()
  • This is the default constructor for the TileResourceSingleThread class.
ProcessRequest(HttpContext)
  • Enables processing of HTTP Web requests by a custom HttpHandler.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#ProcessRequest.28HttpContext.29
  • context
    • Type:HttpContext
    • Description:A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#GetType.28.29
ProcessRequestCore(HttpContext)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#ProcessRequestCore.28HttpContext.29
  • context
    • Type:HttpContext
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#MemberwiseClone.28.29
IsReusable
Gets a value indicating whether another request can use the System.Web.IHttpAsyncHandler instance.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.SingleThreadTileResource#IsReusable
thinkgeo.mapsuite.webedition.singlethreadtileresource.txt · Last modified: 2017/03/16 21:59 (external edit)
