Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
FeatureSourceMarkerOverlay(String,FeatureSource)
GetMarkers(RectangleShape,Int32)
GetMarkersCore(RectangleShape,Int32)
OnClick(MarkerOverlayClickEventArgs)
Gets or sets a feature source object that provides the features from which the markers are created.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#ZoomLevelSet
Gets or sets the grid size in screen coordinate to suppress markers in current Viewport.
Current ViewPort will be split into several cells by FilterGridSize, one cell will contains only one marker in it, in another word, markers which are near too close will be removed. if the value is greater than 0, this function will be enabled.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#IsBaseOverlay
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#IsVisible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#Name
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#IsVisibleInOverlaySwitcher
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#Id
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#AutoRefreshInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#OverlayType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#HasTickEvent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#OnClick.28MarkerOverlayClickEventArgs.29
Event Arguments:MarkerOverlayClickEventArgs
Tick
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
