thinkgeo.mapsuite.webedition.extentchangedeventargs
ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs
Provides data for the ExtentChanged event.
      • ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs
ExtentChangedEventArgs()
  • Initialize an instance of the ExtentChangedEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#ExtentChangedEventArgs.28.29
ExtentChangedEventArgs(RectangleShape,Double)
  • Initialize an instance of the ExtentChangedEventArgs class with the changed extent and scale.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#ExtentChangedEventArgs.28RectangleShape.2C_Double.29
  • currentScale
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#MemberwiseClone.28.29
CurrentExtent
Gets the current extent after the extent is changed.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#CurrentExtent
CurrentScale
Gets the current scale after the extent is changed.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ExtentChangedEventArgs#CurrentScale
thinkgeo.mapsuite.webedition.extentchangedeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
