thinkgeo.mapsuite.webedition.contextmenuitemclickeventargs
ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs
This class provides data for the click event of a context menu item.
      • ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs
ContextMenuItemClickEventArgs()
  • Initialize an instance of the ContextMenuItemClickEventArgs Class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#ContextMenuItemClickEventArgs.28.29
ContextMenuItemClickEventArgs(PointShape)
  • Initialize an instance of ContextMenuItemClickEventArgs Class with the object clicked and the position of the context menu.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#ContextMenuItemClickEventArgs.28PointShape.29
  • location
    • Description:A point shape in world coordinates which indicates the position where you right-clicked on the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#MemberwiseClone.28.29
Location
Gets or sets a point shape that indicates the position where you right-click to pop up the context menu.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenuItemClickEventArgs#Location
thinkgeo.mapsuite.webedition.contextmenuitemclickeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
