thinkgeo.mapsuite.webedition.mousecoordinatetype
ThinkGeo.MapSuite.WebEdition.MouseCoordinateType
This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
The Map.MousePosition.MousePostionType property uses this enumeration to determine which position type appears when the pointer is moving around the map.
Items
LongitudeLatitude
  • Summary:Default mouse position type. Format: “longitude, latitude”.
LatitudeLongitude
  • Summary:Default mouse position type. Format: “latitude, longitude”.
DegreesMinutesSeconds
  • Summary:Appears as degrees, minutes, seconds. Format: “Degressº Minutes Seconds'”. DegreesMinutesSecondsLatitudeLongitude * Summary:Appears as degrees, minutes, seconds. Format: “Degressº Minutes Seconds'”.
thinkgeo.mapsuite.webedition.mousecoordinatetype.txt · Last modified: 2017/03/16 21:59 (external edit)
