This class represents the map control.
GetScreenDistanceBetweenTwoWorldPoints(PointShape,PointShape)
GetWorldDistanceBetweenTwoScreenPoints(ScreenPointF,ScreenPointF,DistanceUnit)
ToScreenCoordinate(Double,Double)
ToScreenCoordinate(PointShape)
ToWorldCoordinate(Single,Single)
ToWorldCoordinate(ScreenPointF)
ZoomToMarkers(IEnumerable<Marker>)
SetTraceData(Object,Object,Object)
GetRouteUrl(RouteValueDictionary)
GetRouteUrl(String,RouteValueDictionary)
GetUniqueIDRelativeTo(Control)
OnDoubleClick(MapClickedEventArgs)
OnBaseOverlayChanged(BaseOverlayChangedEventArgs)
RegisterJavascriptLibraryCore()
RenderChildren(HtmlTextWriter)
EndRenderTracing(TextWriter,Object)
ResolvePhysicalOrVirtualPath(String,VirtualPath&,String&)
RenderChildrenInternal(HtmlTextWriter,ICollection)
RenderControl(HtmlTextWriter,ControlAdapter)
OnBubbleEvent(Object,EventArgs)
SetValidateRequestModeInternal(ValidateRequestMode,Boolean)
CalculateEffectiveValidateRequest()
FindControlFromPageIfNecessary(String)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CallbackResult
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#GeoCanvas
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ZoomLevelSet
When you set your map's width with percentage values (for example, 100%), you might want to know the actual pixel width of your map at a given time. This property returns the map's pixel width as determined by the browser. <strong>Note:</strong> When the map width is a percent value, the <strong>WidthInPixels</strong> is double.NaN only until a postback generates. When the page postbacks, the actual width of the map will be synchronized to this property.
When you set your map's height with percentage values (for example, 100%), you might want to know the actual pixel height of your map at a given time. This property returns the map's pixel height as determined by the browser. <strong>Note:</strong> When the map height is a percent value, the <strong>HeightInPixels</strong> is double.NaN only until a postback generates. When the page postbacks, the actual height of the map will be synchronized to this property.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ClearCachedClientID.28.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#GetUniqueIDRelativeTo.28Control.29
This property determines the background of the map. The map will use the brush defined on this BackgroundLayer to paint the background.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ContextMenu
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CurrentExtent
Gets or sets the cursor that appears when the mouse pointer is over the map control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Cursor
Gets or sets a value that indicates whether the application allows map to register the Web.config on the fly in runtime. The default value is “WebConfigRegisterMode.AutoRegistered”, otherwise, you need to copy the code below to the web.config manually. … …
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#WebConfigRegisterMode
Gets or sets a value that indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “ResourceDeploymentMode.Automatically”, otherwise, you need to copy images to the directory.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ResourceDeploymentMode
The map can contain multiple base overlays, though only one of them can be displayed at a time. The <strong>ActiveBaseOverlay</strong> property specifies the one that is currently displayed. When you switch the base overlays in the <strong>OverlaySwitcher</strong>, the currently selected overlay will be synchronized to this property after postback.
Gets or sets an Overlay object that displays as the background map by default.
The background overlay is one of the base overlays of the map. It can only be the base overlay. If you set a non-base overlay to it, there will be an exception thrown. The background overlay is the active base overlay by default, if you do not set the <strong>ActiveBaseOverlay</strong> property.
The StaticOverlay is a shortcut way for you to add a LayerOverlay to the map. It can only be the base overlay. It is not the active base overlay by default. You need to set it to the ActiveBaseOverlay property in order to display it.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#DynamicOverlay
Gets an InMemoryMarkerOverlay object that renders markers by the specified features.
The MarkerOverlay overlaps on the base overlay and other non-base overlays. It displays markers based on the features you add to it. If you want to render markers by feature source, use the FeatureSourceMarkerOverlay and add it to the CustomOverlays collection.
Gets an Overlay collection, into which you can add different types of overlays.
You can create any type of Overlay object and add it to the CustomOverlays collection. The CustomOverlays collection will disable the BackgroundOverlay, StaticOverlay, DynamicOverlay and MarkerOverlay properties. This means you have two options for using overlays: Either set those overlay properties, or use the CustomOverlays collection. The CustomOverlays collection has higher priority and is more flexible. By contrast, the overlay properties act as shortcut way to use overlays.
Gets an EditOverlay object, with which you can draw and edit shapes at the client.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#EditOverlay
Gets an HighlightFeatureOverlay object, which draws its features at the client side and can attach the specified click event and context menu to them.
The HighlightOverlay actually serializes all its features to the client for drawing. These are client features whose styles changes when you mouse over them, thus generating the mouse-over highlight effect. <strong>Note:</strong> Performance may be slow when the features added to the HighlightOverlay contain many vertices, because serializing and drawing these features at the client side may take some time.
This property gets or sets the adornment overlay in the MapControl.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#AdornmentOverlay
Gets an object that contains all types of map controls for configuration.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#MapTools
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#MapUnit
Gets or sets the client-side script that executes whenever a feature is drawn at the client.
The <strong>OnClientDrawEnd</strong> property holds the Javascript function that will be executed whenever you finish drawing a shape. The Javascript function takes one parameter, which is the feature that you just drew. You can use this parameter to add extra data to the feature (add to feature.fieldValues). You can then retrieve that extra data from the feature's ColumnValues collection after postback.
Gets or sets the client-side script that executes whenever you finish editing a shape at the client.
The <strong>OnClientEditEnd</strong> property holds the Javascript function that will be executed whenever you finish editing a shape. The Javascript function takes one parameter, which is the feature that you just edited. You can use this parameter to edit the extra data of the feature (feature.fieldValues). You can then retrieve that extra data from the feature's ColumnValues collection after postback.
Gets or sets the client-side script that executes when you click on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnClientClick
Gets or sets the client-side script that executes when the map extent changes.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnClientExtentChanged
Gets or sets the client-side script that executes when the current base overlay changes in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnClientBaseOverlayChanged
Gets or sets the client-side script that executes when you double-click on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnClientDoubleClick
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Popups
Gets or sets an extent that limits the area to which the map can be navigated within.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#RestrictedExtent
Gets or sets a double value that indicates the current scale of the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CurrentScale
Gets and sets a custom cursor image URI for the mouse cursor to use when you select 'CursorType.Custom'.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CustomCursorUri
IsDefaultJavascriptLibraryDisabled
Gets or sets whether the default javascript library is disabled or not.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#IsDefaultJavascriptLibraryDisabled
IsDomTreeCollectedWhenPostback
Gets or sets whether collect the DOM tree when Postback.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#IsDomTreeCollectedWhenPostback
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#BackImageUrl
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#DefaultButton
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Pan.28PanDirection.2C_Int32.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#GroupingText
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HorizontalAlign
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#SupportsDisabledAttribute
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ScrollBars
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Wrap
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#AccessKey
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CopyBaseAttributes.28WebControl.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#BackColor
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#BorderColor
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#BorderWidth
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#BorderStyle
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CreateControlStyle.28.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ControlStyleCreated
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CssClass
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ApplyStyle.28Style.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Enabled
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#EnableTheming
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Font
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ForeColor
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasAttributes
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Height
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#SkinID
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#TabIndex
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ToolTip
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ClearEffectiveClientIDMode.28.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#EnableViewState
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ViewStateMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#NamingContainer
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#BindingContainer
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#DataItemContainer
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#DataKeysContainer
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ApplyStyleSheetSkin.28Page.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#RenderingCompatibility
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#TemplateControl
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Parent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#AppRelativeTemplateSourceDirectory
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Site
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Visible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasControls.28.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ValidateRequestMode
Gets a collection of client resolutions for zoom level set.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ClientResolutions
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#StaticOverlayForJson
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#DynamicOverlayForJson
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#MarkerOverlayForJson
Gets the AdornmentOverlay configuration for client side.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#AdornmentOverlayForJson
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#PageName
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasClickEvent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasDoubleClickEvent
Gets a flag whether raise base overlay changed event on the client side.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasBaseLayerChangedEvent
Gets a flag whether raise track shape finished event on the client side.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasTrackShapeEndEvent
Gets a flag whether raise extent changed event on the client side.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasExtentChangedEvent
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CenterX
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#CenterY
Gets a string value indicats the web page's root path for loading the default icons.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#PageRootPath
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#TagKey
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#TagName
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ClientIDSeparator
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#RenderControl.28HtmlTextWriter.2C_ControlAdapter.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Public_Events
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#IdSeparator
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#LoadViewStateByID
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#HasChildViewState
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ClearChildViewState.28.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ViewStateIgnoresCase
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#ChildControlsCreated
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#IsTrackingViewState
The Click event is raised when the map control is clicked.
Event Arguments:MapClickedEventArgs
This event is raised when you double click on the map. <strong>Note:</strong> When you add event handlers to both <strong>Click</strong> and <strong>DoubleClick</strong> events, only the <strong>Click</strong> event will be fired.
This event is raised after you draw a shape on the map. If you add an event handler to this event, each time you draw a shape at the client it will cause the page to postback. You can get the drawn features from the <strong>Map.EditOverlay.Features</strong> collection.
Event Arguments:
This event is raised when you switch the active base overlay in the <strong>OverlaySwitcher</strong> panel; for example, from GoogleOverlay to YahooOverlay. You can handle this event to add your specific logic for that overlay.
Event Arguments:BaseOverlayChangedEventArgs
This event is raised when you pan or zoom the map at the client side and cause the map extent to change.
Event Arguments:ExtentChangedEventArgs
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#Disposed
Event Arguments:
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnDataBinding.28EventArgs.29
Event Arguments:
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnInit.28EventArgs.29
Event Arguments:
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#LoadViewState.28Object.29
Event Arguments:
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnPreRender.28EventArgs.29
Event Arguments:
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Map#OnUnload.28EventArgs.29
Event Arguments:
