<!– Interface –> Allows an object to control its own serialization and deserialization to/from a JSON string.
Any class that wants to utilize the automatic JSON serialization needs to implement this interface. Additionally, the properties that need to be serialized should be marked with the <strong>JsonMember</strong> attribute.
ToJson | Returns a JSON string that contains infomation for the properties marked with the JsonMember attribute of the target object. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.IJsonSerializable#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.IJsonSerializable#ToJson.28.29</a>
| String<!– System.String –> | A JSON string that contains infomation for the properties marked with the JsonMember attribute of the target object. |
<!– ThinkGeo.MapSuite.WebEdition.IJsonSerializable –> Go Back
