thinkgeo.mapsuite.webedition.adornmentoverlay
ThinkGeo.MapSuite.WebEdition.AdornmentOverlay
This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
    • ThinkGeo.MapSuite.WebEdition.Overlay
      • ThinkGeo.MapSuite.WebEdition.AdornmentOverlay
AdornmentOverlay()
  • Initialize an instance of the AdornmentOverlay class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AdornmentOverlay.28.29
AdornmentOverlay(String)
  • Initialize an instance of the AdornmentOverlay class with the overlay identifier specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AdornmentOverlay.28String.29
  • id
    • Description:The identifier string used to retrieve the overlay for collection.
Draw(GeoCanvas)
  • Draw all of the layers to the image object using the parameters specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Draw.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
    • Description:This parameter specifies the target canvas to draw the current AdornmentOverlay on.
ToJson()
  • Returns a JSON string which contains the information for creating an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#ToJson.28.29
  • Description:A JSON string which is used to create an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#GetType.28.29
DrawCore(GeoCanvas)
  • This method overrides the DrawCore logic in the Overlay base class. Draw all of the AdornmentLayers to the image object using the parameters specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#DrawCore.28GeoCanvas.29
  • canvas
    • Type:GeoCanvas
3xM=(Page)
  • page
    • Type:Page
  • Registers a Javascript library URL string to the client HTML page.
  • The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
  • page
    • Type:Page
    • Description:The page object that is used for registering the javascript library.
RaiseTickEvent(EventArgs)
  • e
    • Type:EventArgs
OnTick(EventArgs)
  • Raises the Tick event of the MarkerOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#OnTick.28EventArgs.29
  • e
    • Type:EventArgs
    • Description:An System.EventArgs object that contains the event data.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#MemberwiseClone.28.29
Layers
This property gets a collection of the AdornmentLayers that are added to the AdornmentOverlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Layers
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsVisible
Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Name
Opacity
Gets or sets the opacity level of the overlay.
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
  • Type:Single
IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
IsBaseOverlay
Gets or sets a value that indicates whether the overlay is a base overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsBaseOverlay
Id
Gets the identifier for the overlay to be found.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Id
AutoRefreshInterval
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AutoRefreshInterval
  • Type:TimeSpan
Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Attribution
4RM=
OverlayType
Gets a string that indicates the overlay type.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#OverlayType
HasTickEvent
Indicates whether the overlay supports tick event.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#HasTickEvent
3hM=
Tick Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
thinkgeo.mapsuite.webedition.adornmentoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
