thinkgeo.mapsuite.webedition.openstreetmapoverlay
ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay
This class is used to display data from OpenStreetMap server.
    • ThinkGeo.MapSuite.WebEdition.Overlay
      • ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay
OpenStreetMapOverlay()
Initialize an instance of the OpenStreetMapOverlay class.
OpenStreetMapOverlay(String)
  • id
    • Description:The identifier string of the OpenStreetMapOverlay.
ToJson()
3xM=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
RaiseTickEvent(EventArgs)
  • e
    • Type:EventArgs
OnTick(EventArgs)
  • e
    • Type:EventArgs
CustomServerUris
  • Type:Collection<Uri>
TileWidth
Gets or sets the width of each tile, if the OpenStreetMapOverlay uses tiling.
TileHeight
Gets or sets the height of each tile, if the OpenStreetMapOverlay uses tiling.
MapType
Gets or sets a value to display which tileset for render OpenStreetMap data.
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
IsBaseOverlay
Id
AutoRefreshInterval
  • Type:TimeSpan
Attribution
OverlayType
Gets the type of this overlay which uses for serializing to JSON and parses to a real overlay on the client side.
HasTickEvent
Don't support auto tick event by default.
3hM=
Tick N/A
Event Arguments:EventArgs
thinkgeo.mapsuite.webedition.openstreetmapoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
