thinkgeo.mapsuite.webedition.jsonmemberattribute
ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute
Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
    • System.Attribute
      • ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute
JsonMemberAttribute()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#JsonMemberAttribute.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#GetHashCode.28.29
Match(Object)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#Match.28Object.29
IsDefaultAttribute()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#IsDefaultAttribute.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#MemberwiseClone.28.29
MemberName
Gets or sets the name of the key part in a JSON string.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#MemberName
ValuePropertyName
Gets or sets which part of the property object to be serialized.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#ValuePropertyName
TypeId
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.JsonMemberAttribute#TypeId
thinkgeo.mapsuite.webedition.jsonmemberattribute.txt · Last modified: 2017/03/16 21:59 (external edit)
