thinkgeo.mapsuite.webedition.markeroverlay
ThinkGeo.MapSuite.WebEdition.MarkerOverlay
Serves as the base class for the overlay that generates and manages markers.
MarkerOverlay()
  • Initialize a new instance of the MarkerOverlay class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#MarkerOverlay.28.29
MarkerOverlay(String)
  • Initialize a new instance of the MarkerOverlay class using the identifier specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#MarkerOverlay.28String.29
  • id
    • Description:The identifier string of the MarkerOverlay.
GetMarkers(RectangleShape,Int32)
  • Returns a collection of markers based on the extent and zoomlevel that you passed in.
  • The <strong>GetMarkers</strong> method creates the makrers based on the current zoomlevel, the specified extent and the special logic of the MarkerOverlay. The returned markers object will be serialized and sent to the client to create client markers.
  • Type:Collection<Marker>
  • Description:A collection of marker objects that will be serialized to the client.
  • worldExtent
    • Description:The extent that includes all of the markers you want to serialize.
  • currentZoomLevelId
    • Description:An int value that indicates which zoomlevel the map is currently at.
ToJson()
  • Returns a JSON string which contains the information for creating an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#ToJson.28.29
  • Description:A JSON string which is used to create an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#GetType.28.29
GetMarkersCore(RectangleShape,Int32)
  • The GetMarkersCore method allows derived classes to rewrite the logic used for dynamically creating the markers that will be serialized to the client.
  • Description:A collection of Marker objects that will be serialized to the client.
  • worldExtent
4xM=(String,String)
  • overlayId
  • featureId
OnClick(MarkerOverlayClickEventArgs)
  • Raises the Click event of the MarkerOverlay object.
  • The <strong>OnClick</strong> method also allows derived classes to handle the event without attaching a delegate. This is the preferred technique for handling the event in a derived class. <strong>Notes to Inheritors:</strong> When overriding <strong>OnClick</strong> in a derived class, be sure to call the base class's <strong>OnClick</strong> method so that registered delegates receive the event.
5BM=()
5RM=(Object)
  • target
3xM=(Page)
  • page
    • Type:Page
  • Registers a Javascript library URL string to the client HTML page.
  • The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
  • page
    • Type:Page
    • Description:The page object that is used for registering the javascript library.
RaiseTickEvent(EventArgs)
  • e
    • Type:EventArgs
OnTick(EventArgs)
  • Raises the Tick event of the MarkerOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#OnTick.28EventArgs.29
  • e
    • Type:EventArgs
    • Description:An System.EventArgs object that contains the event data.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#MemberwiseClone.28.29
IsBaseOverlay
Gets or sets a value that indicates whether the overlay is a base overlay.
The MarkerOverlay can only be a non-base overlay. If you set the <strong>IsBaseOverlay</strong> property to true, there will be an exception thrown.
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#IsVisible
Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#Name
Opacity
Gets or sets the opacity level of the overlay.
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
  • Type:Single
IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Id
Gets the identifier for the overlay to be found.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#Id
AutoRefreshInterval
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#AutoRefreshInterval
  • Type:TimeSpan
Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#Attribution
OverlayType
Gets a string that indicates the overlay type.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#OverlayType
HasClickEvent
IsDefault
HasTickEvent
Indicates whether the overlay supports tick event.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#HasTickEvent
3hM=
Click Occurs when a marker in the overlay is clicked.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#OnClick.28MarkerOverlayClickEventArgs.29
Event Arguments:MarkerOverlayClickEventArgs
Tick Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
thinkgeo.mapsuite.webedition.markeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
