<!– Class –>
*System.Object **ThinkGeo.MapSuite.WebEdition.GeoKeyedCollection‹T›
GeoKeyedCollection‹T› | Initializes a new instance of the GeoKeyedCollection class. |
Add | T | Collection<T> | |
Clear | Collection<T> | ||
Contains | T | Collection<T> | |
Contains | String | KeyedCollection<String,T> | |
CopyTo | T[], Int32 | Collection<T> | |
GetEnumerator | Collection<T> | ||
GetKeys | GeoKeyedCollection<T> | ||
IndexOf | T | Collection<T> | |
Insert | Int32, T | Collection<T> | |
MoveDown | Int32 | GeoKeyedCollection<T> | |
MoveDown | String | GeoKeyedCollection<T> | |
MoveDown | T | GeoKeyedCollection<T> | |
MoveTo | T, Int32 | GeoKeyedCollection<T> | |
MoveTo | String, Int32 | GeoKeyedCollection<T> | |
MoveTo | Int32, Int32 | GeoKeyedCollection<T> | |
MoveToBottom | T | GeoKeyedCollection<T> | |
MoveToBottom | String | GeoKeyedCollection<T> | |
MoveToBottom | Int32 | GeoKeyedCollection<T> | |
MoveToTop | Int32 | GeoKeyedCollection<T> | |
MoveToTop | T | GeoKeyedCollection<T> | |
MoveToTop | String | GeoKeyedCollection<T> | |
MoveUp | T | GeoKeyedCollection<T> | |
MoveUp | String | GeoKeyedCollection<T> | |
MoveUp | Int32 | GeoKeyedCollection<T> | |
Remove | T | Collection<T> | |
Remove | String | KeyedCollection<String,T> | |
RemoveAt | Int32 | Collection<T> | |
ToJson | GeoKeyedCollection<T> | Returns a JSON string that contains information about all of the items in the collection. | |
ChangeItemKey | T, String | KeyedCollection<String,T> | |
ClearItems | Collection<T>(overriden) | ||
GetKeyForItem | T | KeyedCollection<String,T>(overriden) | When implemented in a derived class, extracts the key from the specified element. |
InsertItem | Int32, T | Collection<T>(overriden) | |
MemberwiseClone | Object | ||
RemoveItem | Int32 | Collection<T>(overriden) | |
SetItem | Int32, T | Collection<T>(overriden) |
Dictionary | IDictionary<String,T> | KeyedCollection<String,T> | |
Items | IList<T> | Collection<T> |
| item | T<!– T –> |
<!– Collection{T} –> Go Back
| item | T<!– T –> |
| key | String<!– System.String –> |
<!– KeyedCollection{System.String,T} –> Go Back
| array | T[]<!– Tthinkgeo.mapsuite.webedition.geokeyedcollection_t –> | |
| index | Int32<!– System.Int32 –> |
| IEnumerator<T><!– IEnumerator{T} –> |
<!– ThinkGeo.MapSuite.WebEdition.GeoKeyedCollection{T} –> Go Back
| item | T<!– T –> |
| index | Int32<!– System.Int32 –> | |
| item | T<!– T –> |
| item | T<!– T –> |
| item | T<!– T –> | |
| toIndex | Int32<!– System.Int32 –> |
| key | String<!– System.String –> | |
| fromIndex | Int32<!– System.Int32 –> | |
| item | T<!– T –> |
| item | T<!– T –> |
| item | T<!– T –> |
| item | T<!– T –> |
| String<!– System.String –> | A string that contains information about all of the items in the collection. |
| newKey | String<!– System.String –> |
<!– Collection{T}(overriden) –> Go Back
| String<!– System.String –> | The key for the specified element. |
| item | T<!– T –> | The element from which to extract the key. |
<!– KeyedCollection{System.String,T}(overriden) –> Go Back
| item | T<!– T –> |
| item | T<!– T –> |
| IEqualityComparer<String><!– System.Collections.Generic.IEqualityComparer{System.String} –> |
| T<!– T –> |
| T<!– T –> |
| IDictionary<String,T><!– IDictionary{System.String,T} –> |
| IList<T><!– IList{T} –> |
