thinkgeo.mapsuite.windowsphonecore.worldlabelingcandidate
ThinkGeo.MapSuite.WindowsPhoneCore.WorldLabelingCandidate
<!– Class –> This class represents a candidate with world center point information for labeling.
This class is used in the labeling system. We keep track of every potential label in this class as it goes through the labeling rules.
Public MethodWorldLabelingCandidate This is a default constructor for the class.
Public MethodWorldLabelingCandidate String This is a constructor for the class.
Public MethodWorldLabelingCandidate String, PointShape This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCenterPoint PointShape LabelingCandidate This property gets and sets the center point for the center of the label.
Public PropertyCenterPointInWorldCoordinates PointShape This property gets or sets the Center Point position in world Coordinate system.
Public PropertyLabelInformation Collection<LabelInformation> LabelingCandidate This property gets and sets the label information for this label.
Public PropertyOriginalText String LabelingCandidate This property gets and sets the original text for the label.
Public PropertyScreenArea PolygonShape LabelingCandidate This property gets and sets the screen area that encompasses the label.
WorldLabelingCandidate()
If you use this constructor, then you should set the applicable properties manually.
Name Type Description
Go Back
WorldLabelingCandidate(String)
Overloads
This constructor allows you to pass in the text of the label.
originalText String<!– System.String –> This parameter represents the text of the label before it is potentially modified.
Go Back
WorldLabelingCandidate(String, PointShape)
Overloads
This constructor allows you to pass in the text of the label as well as the world center point.
centerPointInWorldCoordinates PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the center of the polygon (in world coordinates) representing the area to be labeled.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
CenterPoint
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.LabelingCandidate –> Go Back
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.WorldLabelingCandidate –> Go Back
LabelInformation
Return Type
Collection<LabelInformation><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.LabelInformation} –>
OriginalText
Return Type
ScreenArea
Return Type
PolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PolygonShape –>
thinkgeo.mapsuite.windowsphonecore.worldlabelingcandidate.txt · Last modified: 2017/03/16 21:59 (external edit)
