<!– Class –> This class represents a candidate for labeling.
This class is used in the internals of the labeling system. We keep track of every potential label in this class as it goes through the labeling rules.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.LabelingCandidate *ThinkGeo.MapSuite.WindowsPhoneCore.WorldLabelingCandidate
LabelingCandidate | This is a constructor for the class. | ||
LabelingCandidate | String, PolygonShape, PointShape | This is a constructor for the class. | |
LabelingCandidate | String, PolygonShape, PointShape, Collection<LabelInformation> | This is a constructor for the class. |
CenterPoint | PointShape | This property gets and sets the center point for the center of the label. | |
LabelInformation | Collection<LabelInformation> | This property gets and sets the label information for this label. | |
OriginalText | String | This property gets and sets the original text for the label. | |
ScreenArea | PolygonShape | This property gets and sets the screen area that encompasses the label. |
If you use this constructor, then you should set the applicable properties manually.
This constructor allows you to pass in the area of the label as well as the center point.
| originalText | String<!– System.String –> | This parameter represents the text of the label before it is potentially modified. |
| simplePolygonInScreenCoordinates | PolygonShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PolygonShape –> | This parameter is a polygon (in screen coordinates) representing the area to be labeled. |
| centerPointInScreenCoordinates | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This parameter is the center of the polygon (in screen coordinates) representing the area to be labeled. |
This constructor allows you to pass in the area of the label and the center point.
| labelInformation | Collection<LabelInformation><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.LabelInformation} –> | This parameter is the labeling information for this labeling candidate. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.LabelingCandidate –> Go Back
