thinkgeo.mapsuite.webedition.georesourcefactory
ThinkGeo.MapSuite.WebEdition.GeoResourceFactory
    • ThinkGeo.MapSuite.WebEdition.GeoResourceFactory
GeoResourceFactory()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#GeoResourceFactory.28.29
GetHandler(HttpContext,String,String,String)
  • Returns an instance of a class that implements the System.Web.IHttpHandler interface.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#GetHandler.28HttpContext.2C_String.2C_String.2C_String.29
  • Type:IHttpHandler
  • Description:A new System.Web.IHttpHandler object that processes the request.
  • context
    • Type:HttpContext
    • Description:An instance of the System.Web.HttpContext class that provides references to intrinsic server objects (for example, Request, Response, Session, and Server) used to service HTTP requests.
  • requestType
    • Description:The HTTP data transfer method (GET or POST) that the client uses.
  • url
    • Description:The System.Web.HttpRequest.RawUrl of the requested resource.
  • pathTranslated
    • Description:The System.Web.HttpRequest.PhysicalApplicationPath to the requested resource.
ReleaseHandler(IHttpHandler)
  • Enables a factory to reuse an existing handler instance.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#ReleaseHandler.28IHttpHandler.29
  • handler
    • Type:IHttpHandler
    • Description:The System.Web.IHttpHandler object to reuse.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#GetType.28.29
GetHandlerCore(HttpContext)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#GetHandlerCore.28HttpContext.29
  • Type:IHttpHandler
  • context
    • Type:HttpContext
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#MemberwiseClone.28.29
thinkgeo.mapsuite.webedition.georesourcefactory.txt · Last modified: 2017/03/16 21:59 (external edit)
