thinkgeo.mapsuite.webedition.classbreakmarkerstyle
ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle
This class represents a style based on class break values.
    • ThinkGeo.MapSuite.WebEdition.MarkerStyle
      • ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle
ClassBreakMarkerStyle()
  • Initialize a new instance of the ClassBreakMarkerStyle class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#ClassBreakMarkerStyle.28.29
ClassBreakMarkerStyle(String)
  • Initialize a new instance of the ClassBreakMarkerStyle class with the columnName specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#ClassBreakMarkerStyle.28String.29
  • columnName
    • Description:The column name in the feature whose value is used to compare and select the break.
ClassBreakMarkerStyle(String,BreakValueInclusion)
  • Initialize a new instance of the ClassBreakMarkerStyle class with the columnName and breakValueInclusion specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#ClassBreakMarkerStyle.28String.2C_BreakValueInclusion.29
  • columnName
  • breakValueInclusion
    • Description:A value that indicates whether or not to include the break value when comparing the break.
ClassBreakMarkerStyle(String,BreakValueInclusion,Collection<MarkerClassBreak>)
  • columnName
  • classBreaks
    • Type:Collection<MarkerClassBreak>
    • Description:A collection of class breaks whose values are compared with the column value to determine which classbreak styles are applied to the markers.
GetMarkers(IEnumerable<Feature>)
  • Returns a collection of markers that are created by the styles defined on the classbreaks.
  • Type:Collection<Marker>
  • features
    • Type:IEnumerable<Feature>
    • Description:A collection of features that the markers are created from.
GetRequiredColumnNames()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#GetRequiredColumnNames.28.29
  • Type:Collection<String>
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#GetType.28.29
GetContextMenusCore()
  • Gets a collection of context menus that are associated with the MarkerStyle.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#GetContextMenusCore.28.29
GetRequiredColumnNamesCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#GetRequiredColumnNamesCore.28.29
ZhQ=()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#MemberwiseClone.28.29
ColumnName
Gets or sets a column name whose value is used to compare and select the break.
You use this property to set the name of the column where the numeric data is stored for your features.
BreakValueInclusion
Gets or sets the value that indicates whether or not to include the break value when comparing the break.
Example: If you have a class break value set to 100 and the break value is included, then 100 is included for this break. If you set the value to excluded, then 100 would match with the break below 100 instead. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works.
ClassBreaks
Gets a collection of class breaks whose values are compared with the column value to determine which ClassBreakStyles are applied to the markers.
The class breaks determine which style to use, based on the break values. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works.
IsActive
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClassBreakMarkerStyle#IsActive
RequiredColumnNames
thinkgeo.mapsuite.webedition.classbreakmarkerstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
