thinkgeo.mapsuite.webedition.cloudpopup
ThinkGeo.MapSuite.WebEdition.CloudPopup
Represents the popups that appear in a cloud (a.k.a. balloon) shape.
    • ThinkGeo.MapSuite.WebEdition.Popup
      • ThinkGeo.MapSuite.WebEdition.CloudPopup
CloudPopup()
  • Initialize an instance of the CloudPopup class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloudPopup.28.29
CloudPopup(String)
  • Initialize an instance of the CloudPopup class with an Id string.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloudPopup.28String.29
  • id
    • Description:The identifier by which you can find the popup.
CloudPopup(String,PointShape)
  • Initialize an instance of the CloudPopup class with an Id string and the position.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloudPopup.28String.2C_PointShape.29
  • id
  • position
    • Description:A point shape in world coordinates that indicates the position of the popup.
CloudPopup(String,PointShape,String)
  • Initialize an instance of the CloudPopup class with an Id string, position and the content of the popup.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloudPopup.28String.2C_PointShape.2C_String.29
  • id
  • position
  • contentHtml
    • Description:An HTML string rendered as the popup content.
CloudPopup(String,PointShape,String,Int32,Int32)
  • Initialize an instance of the CloudPopup class with Id string, position, popup content and size.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloudPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.29
  • id
  • position
  • contentHtml
  • width
    • Description:An int value that indicates the popup's width.
  • height
    • Description:An int value that indicates the popup's height.
CloudPopup(String,PointShape,String,Int32,Int32,Boolean)
  • Initialize an instance of the CloudPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloudPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.29
  • id
  • position
  • contentHtml
  • width
  • height
  • autoPan
    • Description:A boolean value indicating whether to pan the map if necessary to show the full popup.
CloudPopup(String,PointShape,String,Int32,Int32,Boolean,Boolean)
  • Initialize an instance of the CloudPopup class with an Id string, position, popup's content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloudPopup.28String.2C_PointShape.2C_String.2C_Int32.2C_Int32.2C_Boolean.2C_Boolean.29
  • id
  • position
  • contentHtml
  • width
  • height
  • autoPan
  • hasCloseButton
    • Description:A boolean value indicating whether the popup should have a close button.
CloneShallow()
  • Creates a shallow copy of the current popup object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#CloneShallow.28.29
  • Type:Popup
ToJson()
  • Returns a JSON string which contains the popup's information and is used to create the popup at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#ToJson.28.29
  • Description:A string that is used to create the popup at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#MemberwiseClone.28.29
ContentHtml
Gets or sets the content HTML of the popup window.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#ContentHtml
Id
Gets the identifier by which you can find the popup.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Id
Position
Gets or sets a point shape in world coordinates that represents the position of the popup.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Position
Width
Gets or sets the width of the popup.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Width
Height
Gets or sets the height of the popup.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Height
IsVisible
Gets or sets a value that indicates whether the popup is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#IsVisible
Opacity
Gets or sets the opacity level of the popup.
The <strong>Opacity</strong> property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the popup completely invisible.
  • Type:Single
AutoSize
Gets or sets a value that indicates whether the popup is automatically resized to fit its contents.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#AutoSize
AutoPan
Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#AutoPan
HasCloseButton
Gets or sets a value that indicates whether the popup window has a close button in the upper right corner.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#HasCloseButton
OffsetXInPixels
Gets or sets the popup's pixel offset in X direction.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#OffsetXInPixels
OffsetYInPixels
Gets or sets the popup's pixel offset in Y direction.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#OffsetYInPixels
PopupType
Gets a string that represents the type of the Popup object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#PopupType
thinkgeo.mapsuite.webedition.cloudpopup.txt · Last modified: 2017/03/16 21:59 (external edit)
