<!– Class –> This is an asynchronous HTTP handler which is used to handle web map services.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource</a>
*System.Object **ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource
MultiThreadTileResource | This is the default constructor for the TileResource class. |
BeginProcessRequest | HttpContext, AsyncCallback, Object | Initiates an asynchronous call to the HTTP handler. | |
EndProcessRequest | IAsyncResult | Provides an asynchronous process End method when the process ends. | |
ProcessRequest | HttpContext | Enables processing of HTTP Web requests by a custom HttpHandler. | |
BeginProcessRequestCore | HttpContext, AsyncCallback, Object | Initiates an asynchronous call to the HTTP handler. | |
EndProcessRequestCore | IAsyncResult | Provides an asynchronous process End method when the process ends. | |
MemberwiseClone | Object | ||
ProcessRequestCore | HttpContext | Enables processing of HTTP Web requests by a custom HttpHandler. |
IsReusable | Boolean | Gets a value indicating whether another request can use the System.Web.IHttpAsyncHandler instance. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#BeginProcessRequest.28HttpContext.2C_AsyncCallback.2C_Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#BeginProcessRequest.28HttpContext.2C_AsyncCallback.2C_Object.29</a>
| IAsyncResult<!– System.IAsyncResult –> | A System.IAsyncResult that contains information about the status of the process. |
| context | HttpContext<!– System.Web.HttpContext –> | A System.Web.HttpContext object that provides references to intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. |
| cb | AsyncCallback<!– System.AsyncCallback –> | The System.AsyncCallback to call when the asynchronous method call is complete. If cb is null, the delegate is not called. |
| extraData | Object<!– System.Object –> | Any extra data needed to process the request. |
<!– ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#EndProcessRequest.28IAsyncResult.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#EndProcessRequest.28IAsyncResult.29</a>
| result | IAsyncResult<!– System.IAsyncResult –> | A System.IAsyncResult that contains information about the status of the process. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#ProcessRequest.28HttpContext.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#ProcessRequest.28HttpContext.29</a>
| context | HttpContext<!– System.Web.HttpContext –> | A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#BeginProcessRequestCore.28HttpContext.2C_AsyncCallback.2C_Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#BeginProcessRequestCore.28HttpContext.2C_AsyncCallback.2C_Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#EndProcessRequestCore.28IAsyncResult.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#EndProcessRequestCore.28IAsyncResult.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#ProcessRequestCore.28HttpContext.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#ProcessRequestCore.28HttpContext.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#IsReusable” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MultiThreadTileResource#IsReusable</a>
