Represents the ordinary marker style.
PointMarkerStyle(WebImage,CustomPopup)
PointMarkerStyle(WebImage,CustomPopup,ContextMenu)
GetMarkers(IEnumerable<Feature>)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PointMarkerStyle#PointMarkerStyle.28WebImage.2C_CustomPopup.29
Gets or sets a value indicating the interval that should elapse between when the mouse moves over the marker and when its popup window displays.
The <strong>PopupDelay</strong> value is counted in milliseconds. If it is set to 500, the popup will display 500ms after the mouse pointer hovers over the marker.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PointMarkerStyle#PointMarkerStyle.28WebImage.29
Gets or sets a context menu object that displays when you right-click on the marker.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PointMarkerStyle#PointMarkerStyle.28WebImage.2C_CustomPopup.2C_ContextMenu.29
Gets or sets a float value between 0 and 1 that indicates the transparency level of the marker.
The <strong>Opacity</strong> property enables you to specify a level of transparency for the marker. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the marker completely invisible.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PointMarkerStyle#IsActive
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PointMarkerStyle#GetRequiredColumnNames.28.29
