Represents an overlay object that gets images from Microsoft's Virtual Earth server.
BingMapsOverlay(String,BingMapsStyle)
BingMapsOverlay(BingMapsStyle,String)
BingMapsOverlay(String,BingMapsStyle,String)
BingMapsOverlay(String,String)
BingMapsOverlay(String,String,BingMapsStyle)
Gets or sets the Bing Maps key registered from https://www.bingmapsportal.com/, it will be used to authenticate against any of the REST Services APIs.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#Credentials
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#MapType
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#IsVisible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#Name
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay is a base overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#IsBaseOverlay
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#Id
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#AutoRefreshInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#OverlayType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#HasTickEvent
Tick
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.BingMapsOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
