A
This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
B
Provides data for the BaseOverlayChangedEventArgs event.
Represents an overlay object that gets images from Microsoft's Bing Map server.
C
This class represents a style based on class break values.
This class controls how the map images are cached by the browser.
Represents the popups that appear in a cloud (a.k.a. balloon) shape.
A kind of MarkerStyle to filter the markers.
This class represents a right-click shortcut menu used in the map control.
This class represents a menu item of the ContextMenu control.
This class provides data for the click event of a context menu item.
Represents a pop up window whose style and background can be customized.
E
Represents a FeatureOverlay whose features can be added or edited at the client side.
Provides editing options when the EditOverlay is in EditShape mode.
Provides data for the ExtentChanged event.
F
Serves as the base class for the overlays that contain features and paint the features at client side.
Specifies how the features in a FeatureOverlay are drawn at the client side.
Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
G
Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
Represents an overlay object that gets images from the Google Maps server.
H
Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
This class provides data for the click event of the HighlightFeatureOverlay class.
I
Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
J
Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
K
Determines whether the map can be operated by keyboard.
L
Represents an Overlay that contains layers.
Represents a small image that displays at the center of the map when the map is loading.
Represents a company logo or other logo-type image that displays in the lower right corner of the map.
M
This class represents the map control.
This class provides the data for the click event of the map control.
Provides design-time display of web control.
Defines the properties and methods that are shared by all controls on the map.
Contains the different map tools as properties and acts as an entrance for setting these map controls.
Represents a small icon on the map that is used for marking a point.
Represents a break with a value and style defined.
Provides data for the MarkerDragged event of the SimpleMarkerOverlay.
Serves as the base class for the overlay that generates and manages markers.
Provides data for the Click event of the MarkerOverlay.
This class is the base class for all classes that define the styles applied to the markers.
This class represents one value in a ValueMarkerStyle.
Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
Represents the measure map tool which allows measurements for features.
Represents a mini map panel in the lower right corner of the map.
Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
Determines whether the map can be operated by mouse.
This is an asynchronous HTTP handler which is used to handle web map services.
O
This class is used to display data from OpenStreetMap server.
Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
P
Represents the panning and zooming panel in the upper left corner of the map.
Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
Represents the ordinary marker style.
Serves as the base class that defines the methods and properties common to all types of popups.
S
Represents a graphic line marked with numbers indicating the map's current scale.
This class controls the cachablity of the map control at the server side.
Represents a MarkerOverlay object to which you can add markers directly.
T
V
This class allows you to match a value with data in the feature to determine how to draw the feature.
W
Represents a small image that displays on the map.
Represents an overlay object that gets map images from the WMS server you specify.
Represents an overlay object that gets map images from the WMS servers.
B
This enumeration specifies the map types available from Bing maps.
C
This enumeration determines the cursor that appears when the pointer moves over the map.
G
This enumeration specifies the map types available from Google Maps.
M
This enumeration specifies how the map markers can be dragged.
Defines the different types of the MeasureMapTool.
The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
O
R
This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
T
This enumeration specifies whether the overlay uses tiling.
Defines the different modes of the EditFeatureOverlay.
Defines the different zoom box key code of key for the MouseMapTool.
This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
W
This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
Indicates whether the overlay wraps at the date line.
I
Allows an object to control its own serialization and deserialization to/from a JSON string.
This interface defines an Id property that is used by the GeoKeyedCollection.
