A
This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
B
This class inherits from the Overlay abstract class. The specified overlay specifies the background information of the MapControl.
C
Provides data for the ControlPointSelected event.
Provides data for the CurrentExtentChanged event.
Provides data for the CurrentExtentChanging event.
Provides data for the CurrentScaleChanged event.
Provides data for the CurrentScaleChanging event.
D
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the Overlay has been drawn.
E
This class inherits from the InterativeOverlay abstract class. This specified overlay describes the EditShape interactive process with the MapControl using the Mouse or Keyboard.
This class inherits from the interactiveOverlay abstract class. This specified overlay describes the Extent Changing interactive process with the MapControl using the Mouse or Keyboard.
F
Provides data for the FeatureDragged event.
Provides data for the FeatureDragging event.
Provides data for the FeatureResized event.
Provides data for the FeatureResizing event.
Provides data for the FeatureRotated event.
Provides data for the FeatureRotating event.
G
This class represents the Overlay used to display a Google Map.
I
This class encapsulates the information and simple method for interative actions.
This class inherits from Overlay abstract class. This specified overlay describes the interative process with the MapControl using the Mouse or Keyboard.
This class specifies the InterativeResult when dealing with the Interative method in InterativeOverlay.
K
This class encapsulates the information and simple method for key events interative actions.
L
: This class represents a group of layers; each layer can be of any layer type.
M
Provides data for the WinformsMap or WpfMap's MapClick event.
Provides data for the MapKeyDown event.
Provides data for the MapKeyUp event.
Provides data for the MapMouseClick event.
Provides data for the MapMouseDoubleClick event.
Provides data for the MapMouseDown event.
Provides data for the MapMouseMove event.
Provides data for the MapMouseUp event.
Provides data for the MapMouseWheel event.
This class represents the event arguments for the MarkerDragged event for SimpleMarkerOverlay.
This class represents the MarkerDragging event argument for SimpleMarkerOverlay.
This class represents the base class for all classes that defines the styles applied to the markers.
This class defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class represents a collection of MarkerZoomLevel that determines the appearance of markers at different zoomlevels.
Provides data for the MouseMoved event.
O
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This class defines a lock that supports a single writer and multiple readers.
This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn.
P
This class stores the information for Pan and Track Zoom.
This class represents the ordinary point marker style.
R
S
This class is a concrete class that inherits from FileBitmapTileCache. In this class, the tiles will be marked as obsolete when you call the ClearCache method and will be deleted in a background thread.
T
This class is used in Desktop Edition to access the WMS Server.
Provides data for the TrackEnded event.
Provides data for the TrackEnding event.
This class inherits from the interactiveOverlay abstract class. This specified overlay describes the TrackShape interactive process with the MapControl using the Mouse or Keyborad.
Provides data for the TrackStarted event.
Provides data for the TrackStarting event.
V
Provides data for the VertexAdded event.
Provides data for the VertexAdding event.
Provides data for the VertexMoved event.
Provides data for the VertexMoving event.
Provides data for the VertexRemoved event.
Provides data for the VertexRemoving event.
W
The Map Control used to develop a Winforms application.
This class is used in Desktop Edition to access the WMTS Server.
This class is used in Desktop Edition to access the WorldMapKit Web Map Service (WMS).
The Map Control used to develop a WPF application.
C
This enumeration specifies the control point type when editing a shape. The deafault value is None.
E
This enumeration specifies the type of extent change that has occurred when doing interactive actions with InterativeOverlay.
I
This enumeration specifies the mode in which to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
M
This enumeration specifies the behavior that occurs when double-left-clicking on the MapControl. The default value is ZoomIn.
This enumeration specifies the behavior that occurs when double-right-clicking on the MapControl. The default value is ZoomOut.
The enumeration specifies the focus mode that will be used for map to take focus. The default value is MouseEnterFocused.
This enumeration specifies the behavior that occurs when you left-click-and-drag on the MapControl. The default value is ZoomInWithKey.
This enumeration defines a MouseButton for MapControl.
This enumeration specifies the behavior that occurs when the mouse wheel is scrolled. The default value is Zooming.
This enumeration specifies the behavior type for panning. The default value is StandardPanning.
This enumeration specifies the behavior that occurs when you right-click-and-drag on the MapControl. The default value is ZoomOutWithKey.
This enumation provides two threading options when refreshing the map. The default value is SingleThreaded.
This enumeration specifies how the map markers can be dragged.
P
This enumeration specifies the mode used to process other overlays when doing interactive actions with InterativeOverlay.
T
This enumeration specifies the existence status for the current extent tiles.
The TrackMode enumeration determines how the map will react to user interaction.
V
This enumeration specifies the control points connect mode when reshape a shape. The deafault value is None.
Z
This enumation provides the options used to set the ZoomLevel Snapping Mode. In SnapUp or Default mode, there are only 20 preset ZoomLevels whose scales are set accordingly with OpenLayers' scales. You can change this by setting the SnappingMode to None, but in doing so, you will lose the ability to use the TileCache system.
