thinkgeo.mapsuite.desktopedition.featureresizededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs
Provides data for the FeatureResized event.
      • ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs
FeatureResizedEditInteractiveOverlayEventArgs()
FeatureResizedEditInteractiveOverlayEventArgs(Feature)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs#FeatureResizedEditInteractiveOverlayEventArgs.28Feature.29
  • resizedFeature
    • Type:Feature
    • Description:This parameter specifies the feature resized.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
ResizedFeature
  • This property gets or sets the Feature resized.
thinkgeo.mapsuite.desktopedition.featureresizededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
