thinkgeo.mapsuite.desktopedition.trackmode
ThinkGeo.MapSuite.DesktopEdition.TrackMode
  • The TrackMode enumeration determines how the map will react to user interaction.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackMode// == Items == None * Summary:Default mode. Point * Summary:Point drawing mode. Line * Summary:Line drawing mode. Polygon * Summary:Polygon drawing mode. Rectangle * Summary:Rectangle drawing mode. Square * Summary:Square drawing mode. Circle * Summary:Circle drawing mode. Ellipse * Summary:Ellipse drawing mode. StraightLine * Summary:Allows the user to draw a simple line with only 2 points on the map. Freehand * Summary:Allows the user to draw freehand on the map. Custom * Summary:Allows the user to draw a custom track shape on the map.
thinkgeo.mapsuite.desktopedition.trackmode.txt · Last modified: 2017/03/16 21:59 (external edit)
