This class defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
GetMarkers(IEnumerable<Feature>)
ApplyUntilZoomLevel
* Gets or sets the zoomlevel to which the styles will be applied.
== Remarks ==
== Return Value ==
* Type:ApplyUntilZoomLevel
DefaultPointMarkerStyle
* Gets default style that is applied to the markers if the CustomMarkerStyle is not defined.
== Remarks ==
* Gets the style that is applied to the markers if the CustomMarkerStyle is not defined.
== Return Value ==
* Type:PointMarkerStyle
CustomMarkerStyle
* Gets or sets a custom style that can be any type of MarkerStyle.
== Remarks ==
* The CustomMarkerStyle has a higher priority than the DefaultMarkerStyle. When you define both styles, the CustomMarkerStyle will be applied. The CustomMarkerStyle can be any kind of MarkStyle while DefaultMarkerStyle can not.
== Return Value ==
* Type:MarkerStyle
==== Protected Properties ====
==== Public Events ====
