thinkgeo.mapsuite.desktopedition.currentscalechangingwpfmapeventargs
ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs
Provides data for the CurrentScaleChanging event.
      • ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs
CurrentScaleChangingWpfMapEventArgs()
  • Initialize an instance of the CurrentScaleChangingEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28.29
CurrentScaleChangingWpfMapEventArgs(RectangleShape,Double,Double,GeographyUnit,Single,Single,Boolean)
  • Initialize an instance of the CurrentScaleChangingEventArgs class by passing the currentScale, mapUnit, mapWidth and mapHeight.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28RectangleShape.2C_Double.2C_Double.2C_GeographyUnit.2C_Single.2C_Single.2C_Boolean.29
  • currentScale
  • newScale
  • mapWidth
    • Type:Single
  • mapHeight
    • Type:Single
  • cancel
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangingWpfMapEventArgs#MemberwiseClone.28.29
CurrentScale
  • This property specifies the CurrentScale of the CurrentScaleChangingEventArgs.
NewScale
  • This property specifies the NewScale of the CurrentScaleChangingEventArgs.
MapWidth
  • This property specifies the MapWidth of the CurrentScaleChangingEventArgs.
  • Type:Single
CurrentExtent
  • This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs.
thinkgeo.mapsuite.desktopedition.currentscalechangingwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
