thinkgeo.mapsuite.desktopedition.controlpointtype
ThinkGeo.MapSuite.DesktopEdition.ControlPointType
  • This enumeration specifies the control point type when editing a shape. The deafault value is None.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ControlPointType// == Items == None * Summary:Default value of this enumeration. Drag * Summary:This enumeration item means that the control point is used to Drag. Rotate * Summary:This enumeration item means that the control point is used to Rotate. Resize * Summary:This enumeration item means that the control point is used to Resize. Vertex * Summary:This enumeration item means that the control point is used to change the vertex postion.
thinkgeo.mapsuite.desktopedition.controlpointtype.txt · Last modified: 2017/03/16 21:59 (external edit)
