thinkgeo.mapsuite.desktopedition
ThinkGeo.MapSuite.DesktopEdition
DesktopEdition
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
B
  • BackgroundOverlay
    This class inherits from the Overlay abstract class. The specified overlay specifies the background information of the MapControl.
C
D
E
  • EditInteractiveOverlay
    This class inherits from the InterativeOverlay abstract class. This specified overlay describes the EditShape interactive process with the MapControl using the Mouse or Keyboard.
  • ExtentInteractiveOverlay
    This class inherits from the interactiveOverlay abstract class. This specified overlay describes the Extent Changing interactive process with the MapControl using the Mouse or Keyboard.
F
G
I
  • InteractionArguments
    This class encapsulates the information and simple method for interative actions.
  • InteractiveOverlay
    This class inherits from Overlay abstract class. This specified overlay describes the interative process with the MapControl using the Mouse or Keyboard.
  • InteractiveResult
    This class specifies the InterativeResult when dealing with the Interative method in InterativeOverlay.
K
L
M
O
  • Overlay
  • OverlayDrawingWinformsMapEventArgs
    This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
  • OverlayDrawingWpfMapEventArgs
    This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised before any of the overlays are drawn.
  • OverlayDrawnWinformsMapEventArgs
    This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn.
  • OverlayDrawnWpfMapEventArgs
  • OverlayLock
    This class defines a lock that supports a single writer and multiple readers.
  • OverlaysDrawingWinformsMapEventArgs
    This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
  • OverlaysDrawingWpfMapEventArgs
  • OverlaysDrawnWinformsMapEventArgs
    This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn.
  • OverlaysDrawnWpfMapEventArgs
P
R
S
  • SessionFileBitmapTileCache
    This class is a concrete class that inherits from FileBitmapTileCache. In this class, the tiles will be marked as obsolete when you call the ClearCache method and will be deleted in a background thread.
T
V
W
Structures
Enums
C
  • ControlPointType
    This enumeration specifies the control point type when editing a shape. The deafault value is None.
E
  • ExtentChangedType
    This enumeration specifies the type of extent change that has occurred when doing interactive actions with InterativeOverlay.
I
  • InteractiveOverlayDrawType
    This enumeration specifies the mode in which to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
M
  • MapDoubleLeftClickMode
    This enumeration specifies the behavior that occurs when double-left-clicking on the MapControl. The default value is ZoomIn.
  • MapDoubleRightClickMode
    This enumeration specifies the behavior that occurs when double-right-clicking on the MapControl. The default value is ZoomOut.
  • MapFocusMode
    The enumeration specifies the focus mode that will be used for map to take focus. The default value is MouseEnterFocused.
  • MapLeftClickDragMode
    This enumeration specifies the behavior that occurs when you left-click-and-drag on the MapControl. The default value is ZoomInWithKey.
  • MapMouseButton
    This enumeration defines a MouseButton for MapControl.
  • MapMouseWheelMode
    This enumeration specifies the behavior that occurs when the mouse wheel is scrolled. The default value is Zooming.
  • MapPanMode
    This enumeration specifies the behavior type for panning. The default value is StandardPanning.
  • MapRightClickDragMode
    This enumeration specifies the behavior that occurs when you right-click-and-drag on the MapControl. The default value is ZoomOutWithKey.
  • MapThreadingMode
    This enumation provides two threading options when refreshing the map. The default value is SingleThreaded.
  • MarkerDragMode
    This enumeration specifies how the map markers can be dragged.
P
  • ProcessOtherOverlaysMode
    This enumeration specifies the mode used to process other overlays when doing interactive actions with InterativeOverlay.
T
  • TilesExistingType
    This enumeration specifies the existence status for the current extent tiles.
  • TrackMode
    The TrackMode enumeration determines how the map will react to user interaction.
V
Z
  • ZoomLevelSnappingMode
    This enumation provides the options used to set the ZoomLevel Snapping Mode. In SnapUp or Default mode, there are only 20 preset ZoomLevels whose scales are set accordingly with OpenLayers' scales. You can change this by setting the SnappingMode to None, but in doing so, you will lose the ability to use the TileCache system.
Interfaces
thinkgeo.mapsuite.desktopedition.txt · Last modified: 2017/03/16 21:59 (external edit)
