thinkgeo.mapsuite.desktopedition.featurerotatededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs
Provides data for the FeatureRotated event.
      • ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs
FeatureRotatedEditInteractiveOverlayEventArgs()
FeatureRotatedEditInteractiveOverlayEventArgs(Feature)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#FeatureRotatedEditInteractiveOverlayEventArgs.28Feature.29
  • rotatedFeature
    • Type:Feature
    • Description:This parameter specifies the feature rotated.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
RotatedFeature
  • This property gets or sets the Feature rotated.
thinkgeo.mapsuite.desktopedition.featurerotatededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
