thinkgeo.mapsuite.desktopedition.trackendedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs
Provides data for the TrackEnded event.
      • ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs
TrackEndedTrackInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
TrackEndedTrackInteractiveOverlayEventArgs(BaseShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#TrackEndedTrackInteractiveOverlayEventArgs.28BaseShape.29
  • trackShape
    • Type:BaseShape
    • Description:This parameter specifies the tracked shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29
TrackShape
This property gets or sets the tracked shape.
thinkgeo.mapsuite.desktopedition.trackendedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
