thinkgeo.mapsuite.desktopedition.mapfocusmode
ThinkGeo.MapSuite.DesktopEdition.MapFocusMode
  • The enumeration specifies the focus mode that will be used for map to take focus. The default value is MouseEnterFocused.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapFocusMode// == Items == Default * Summary:Default value (MouseEnterFocused) of the enumeration. MouseEnterFocused * Summary:This item means that MapControl will take focus when the mouse enters the MapControl. ManuallyFocused * Summary:This item means that the MapControl will only take focus when the mapControl.Focus() API is called.
thinkgeo.mapsuite.desktopedition.mapfocusmode.txt · Last modified: 2017/03/16 21:59 (external edit)
