thinkgeo.mapsuite.desktopedition.markerzoomlevelset
ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet
This class represents a collection of MarkerZoomLevel that determines the appearance of markers at different zoomlevels.
    • ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet
MarkerZoomLevelSet()
  • Initialize a new instance of the MarkerZoomLevelSet class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#MarkerZoomLevelSet.28.29
GetZoomLevelForDrawing(Int32)
  • Returns the MarkerZoomLevel object whose styles will be applies to the markers base on the current zoomlevel that passed in.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#GetZoomLevelForDrawing.28Int32.29
  • Description:The MarkerZoomLevel object whose styles will be applies to the markers base on the current zoomlevel that passed in.
  • currentZoomLevelId
    • Description:An int value that indicates which zoomlevel is the current zoomlevel. The int value can only be in 1-20.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#GetType.28.29
6xQ=(Int32)
  • id
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MarkerZoomLevelSet#MemberwiseClone.28.29
ZoomLevel01
  • Gets the MarkerZoomLevel for Level01.
ZoomLevel03
  • Gets the MarkerZoomLevel for Level03.
ZoomLevel05
  • Gets the MarkerZoomLevel for Level05.
ZoomLevel07
  • Gets the MarkerZoomLevel for Level07.
ZoomLevel09
  • Gets the MarkerZoomLevel for Level09.
ZoomLevel11
  • Gets the MarkerZoomLevel for Level11.
ZoomLevel13
  • Gets the MarkerZoomLevel for Level13.
ZoomLevel15
  • Gets the MarkerZoomLevel for Level15.
ZoomLevel17
  • Gets the MarkerZoomLevel for Level17.
ZoomLevel19
  • Gets the MarkerZoomLevel for Level19.
CustomZoomLevels
  • Gets a MarkerZoomLevel collection that is used for you to define your own custom zoomlevels.
  • When you add custom zoomlevels to the CustomZoomLevels collection, the default ZoomLevel01-20 will be disabled. The zoomLevels in the CustomZoomLevels are matched with the scales defined in the Map.ZoomLevelScales. For example, CustomZoomLevels[0] has the scale that equals to Map.ClientZoomLevelScales[0].
thinkgeo.mapsuite.desktopedition.markerzoomlevelset.txt · Last modified: 2017/03/16 21:59 (external edit)
