This class is used in Desktop Edition to access the WorldMapKit Web Map Service (WMS).
WorldMapKitWmsDesktopOverlay(String,String)
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType,String,String)
WorldMapKitWmsDesktopOverlay(WebProxy,String,String)
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType,WebProxy,String,String)
OnSendingWebRequest(SendingWebRequestEventArgs)
OnDrawing(DrawingOverlayEventArgs)
OnDrawn(DrawnOverlayEventArgs)
RefreshCore(GeoCanvas,RectangleShape)
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
PrivateKey
* Gets or sets a value that is unique to your client ID, please keep your key secure.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#PrivateKey//
MapType
* N/A
== Remarks ==
== Return Value ==
* Type:WorldMapKitMapType
Projection
* Gets or sets the Projection of the Overlay.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Projection//
WebProxy
* This property gets or sets the proxy used for requesting a Web Response.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#WorldMapKitWmsDesktopOverlay.28WebProxy.2C_String.2C_String.29//
Lock
* This property gets the OverlayLock object.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Lock//
DrawingExceptionMode
* This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#DrawingExceptionMode//
* Gets or sets the name of the overlay, which can be used to represent a specific overlay.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#Name//
IsEmpty
* This property can be overridden by its base class. If it is not overridden, its default return value will be false. If this property is empty, we can skip drawing to achieve better performance.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#IsEmpty//
SentWebRequest
* N/A
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29//Event Arguments:SentWebRequestEventArgs
Drawn
* This event will be fired after the Overlay is drawn.
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawn.28DrawnOverlayEventArgs.29//Event Arguments:DrawnOverlayEventArgs
DrawnAttribution
* N/A
== Remarks ==
* For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29//Event Arguments:DrawnAttributionOverlayEventArgs
Event Arguments:RequestedDrawingOverlayEventArgs
Event Arguments:RequestingDrawingOverlayEventArgs
