thinkgeo.mapsuite.desktopedition.currentextentchangedwpfmapeventargs
ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs
Provides data for the CurrentExtentChanged event.
      • ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs
CurrentExtentChangedWpfMapEventArgs()
  • Initialize an instance of the CurrentExtentChangedEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28.29
CurrentExtentChangedWpfMapEventArgs(RectangleShape,GeographyUnit,Single,Single)
  • Initialize an instance of the CurrentExtentChangedEventArgs class by passing the currentExtent, mapUnit, mapWidth and mapHeight.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28RectangleShape.2C_GeographyUnit.2C_Single.2C_Single.29
  • mapWidth
    • Type:Single
  • mapHeight
    • Type:Single
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentExtentChangedWpfMapEventArgs#MemberwiseClone.28.29
CurrentExtent
  • This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs.
MapUnit
  • This property specifies the MapUnit of the CurrentExtentChangedEventArgs.
  • Type:Single
MapHeight
  • This property specifies the MapHeight of the CurrentExtentChangedEventArgs.
thinkgeo.mapsuite.desktopedition.currentextentchangedwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
