thinkgeo.mapsuite.silverlightcore
ThinkGeo.MapSuite.SilverlightCore
SilverlightMapSuiteCore
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
B
C
D
E
  • EditTools
  • EllipseShape
  • ExceptionDescription
    A strongly-typed resource class, for looking up localized strings, etc.
  • ExtentHelper
    This static class exposes a number of helpful methods when dealing with extents.
F
  • FeatureCache
  • FeatureLayer
  • FeatureSource
  • FeatureSourceColumn
G
I
L
  • LabelInformation
    This class represents the location of a piece of a label that may be drawn.
  • LabelingCandidate
    This class represents a candidate for labeling.
  • Layer
    This class is the base class for all types of Layers.
  • LayerDrawingEventArgs
  • LayerDrawnEventArgs
  • LayersDrawingEventArgs
  • LayersDrawnEventArgs
  • LineBaseShape
  • LineShape
  • LineStyle
    This class is the style used to draw lines.
  • LineStyles
    This class is a collection of predefined styles and helper methods to create styles.
M
  • Matrix
    This class represents a base Matrix which encapsulate the tile caculation logics.
  • MultilineShape
  • MultipleFeatureSource
    This MultipleFeatureSource is a special FeatureSource which holds a bunch of FeatureSource.
  • MultipointShape
    This class represents one or more point shapes.
  • MultipolygonShape
O
P
Q
R
S
T
  • TextStyle
  • TextStyleAdvanced
  • TextStyles
  • TileMatrix
  • TinyGeoFeatureLayer
  • TinyGeoFeatureSource
  • TransactionBuffer
  • TransactionResult
V
  • ValueItem
    This class represents a single value to match and styles to draw.
  • ValueStyle
    This class allows you to match a value with data in the feature to determine how to draw that feature.
W
Z
  • ZoomLevel
  • ZoomLevelSet
Structures
C
D
F
  • Feature
G
  • GeoColor
R
S
  • ScreenPoint
  • ShapeValidationResult
V
  • Vertex
Enums
A
  • ApplyUntilZoomLevel
  • AreaUnit
    Units describing various ways you can measure areas.
B
  • BreakValueInclusion
    In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
  • BufferCapType
  • BuildIndexMode
    This enumeration represents whether an index should be rebuilt or not.
  • BuildRecordIdMode
    This enumeration represents whether a record ID should be rebuilt or not.
D
  • DbfColumnType
    This enumeration represents the column type in the DBF.
  • DistanceUnit
    Units describing various ways you can measure lengths.
  • DrawingExceptionMode
    This enum is used to describe some choice when exception hanppens during drawing Layers or Overlays.
  • DrawingFontStyles
    This enumeration specifies the type of font style for drawing text.
  • DrawingGraphicsUnit
    This enumeration represents the graphics unit.
  • DrawingLevel
    This enumeration represents the drawing level used in the GeoCanvas.
  • DrawingLineCap
  • DrawingLineJoin
    This enumeration specifies how to join consecutive line or curve segments.
  • DrawingPenAlignment
G
L
M
O
  • OverwriteMode
P
Q
  • QueryType
R
S
  • ShapeFileReadWriteMode
    This enumeration represent read only or read-write nature of a Shape File.
  • ShapeFileType
    This enumeration represents the types stored in the Shape File.
  • ShapeValidationMode
    This enumeration describes the type of validation test to run on shapes.
  • SimplificationType
    Specifies which algorthm will be use to simplify.
  • SplineType
    This enumeration represents the spline type for labeling.
  • StartingPoint
    An enumeration describing the place to start on a line when doing certain operations.
T
  • TileImageFormat
  • TinyGeoPrecisionMode
  • TransactionResultStatus
W
  • WellKnownType
    This describes a set of enumerations that list the valid types of geometries.
  • WkbByteOrder
    This enumeration represents the byte order that well-known binary will be written in.
Interfaces
thinkgeo.mapsuite.silverlightcore.txt · Last modified: 2017/03/16 21:59 (external edit)
